OT: gutter cleaning robot *LINK*
Dan Mitchell
>Anyone think this thing could actually work? Made by a company that makes those "carpet vacuuming robots". Apparently, they also make things like bomb disposal robots. Check out the video link on this page. Their demo gutter looks pretty tame compared with some of mine, several of which are LOADED with TONS of wet pine needles and are located at vertiginous heights! I'd spring for this gizmo in a second if I thought it would really do the job.
Dan
Gutter cleaning robot
Re: OT: gutter cleaning robot *LINK*
Glenn Madsen, near San Francisco
>Somebody has to go first. Why not you? ;)
I wonder if it could handle eucalyptus leaves, mixed with split leaf maple and birch?
And what happens with corners? Reposition the ladder, I guess.
Lee Schierer - McKean, PA
>I watched their video and it looks like it worked on dry stuff, but wasn't 100% effective as there was visible debris left behind. You might have to run it through 2-3 times to get all the stuff out. You would also have to climb up to each section of guttering as it doesn't go around corners.
Unless you shared it with a couple of neighbors, it wouldn't seem to be price justified for a single home onwner. Might work for a gutter cleaning business though.
Mark Williamson
>I am a self employed handyman and have cleaned MANY gutters. Although having a robot to do ANYTHING has a certain coolness factor to it, I don't see this being very effective on most gutters. I have found that the gutter gaurds are the most effective thing that one can purchase for your gutters. After all, if you keep the crap from going in, you won't have to clean the crap out! LOL I watched the video and if you notice, in more than one shot, it did not clean the leaves out. Another thing I noticed is that those were dry leaves. Also, more often than not, I see that most gutters get loaded with the sand particles that have worked loose from the shingles. I don't see where this thing would be able to do anything for that. 100% of the time I am asked to clean out the gutters, a problem already exists! Most people don't even think about the gutters being cleaned until they see them overflowing.
Cool factor = 10
effectiveness = 3
They have it on "Ask This Old House" tonight..
awh
Dan Mitchell
>The cost doesn't seem too high, the basic model is only $99, if it actually did the job. I've got to think paying for a cleaning on this house, with a lot of high gutters, would be a couple hundred bucks, at least.
Dan Mitchell
>Mark - Thanks for the reply. I agree with everything you've said. I haven't cleaned the gutters here yet (moved in last April) but at my last house in Ohio I did them every year. We had 2 mature pin oaks in the front & several maples in the back which had them full to overflowing by Thanksgiving. Over the years there, I used every method you can think of. Leaf blower, hose, just by hand, etc. The last few years I employed a large shop vac which did an excellent job, only problem being the fairly frequent emptying. The trouble is here some of the gutters are very high up with uneven terrain below. Makes the frequent ladder moves a real pain as well as dangerous.
One concern I'd have about the "robot" is that often times the shingles overhang the gutters in spots to the point it's hard enough getting your hand in there, let alone this thing. I could see it getting stuck in such a spot, naturally in one of the 25' above the ground portions, & being a real PITA. Even so, I hate this job so much I might be willing to give it a try if there's a money back guarantee, I emailed them asking about this.
My concern about gutter guards has always been that the ones which cover well enough to block the debris, especially pin needles as we have here, might also block the rain in a really heavy downpour.
Dan
Thanks, I'll check it out!
Dan Mitchell
Mark Williamson
>The way I look at it is if you spend $100 on a robot that doesn't do the job good at all then you have to spend $300 to get someone out to show them your new $100 nerf battlebot that could polish a mean toenail and $200 for him to go up and clean the gutters. If you spend $200 or so to have someone come out and maintain them once a year then
a) If it isn't done right you can have them redo it until it is right.
b) You then don't have to climb the ladder at all. (Unless you want to play with your new battlebot while the handyman cleans the gutters. LOL)
c) that price should also include spraying water down to wash out ALL debri, checking for any loose gutter sections, hammering in any gutter nails that are working out, removing any larger items that would most definatly stop your nerf robo toepolisher dead in its tracks. They should also check for any other visible roof damage as well as any other potential problems that you omay have going on, any loose downspouts and if they are a good little handyman like myself, ahem, they would probably even remove anything that is on the roof that is eventually going to work its way to the gutter.
Just some things to think about. :)
ScottS
>I have one of iRobot's floor vacuuming robots. For my hardwood floors, it works pretty well! I find that it does a much better job if I run it once a day or every other day than waiting weeks between cleanings. It wouldn't surprise me if the gutter cleaning robot is similar. If you only run it one a year and your gutters are completely clogged, it probably has a difficult time cleaning. If you run it 2-4 times a year, so that it has less debris to deal with each time, it probably does a better job. While it may not get your gutters clean enough to eat out of, you should also think about how clean they really need to be... For myself, I wouldn't mind the robot leaving a small amount of debris behind if it meant I didn't have to hassle with any of the cleaning!
Dan Mitchell
>Well you know, much of the reason I do LOTS of things I'd rather not isn't that I'm too cheap to pay someone, it's that FINDING someone who will 1) show up when they say 2) do the job properly 3) not hose something else up in the process 4) return for a redo if necessary has been, in my perhaps unluckier-than-most-experience, next to impossible. The extensive, multi-section gutters on our current place are in good shape (save a short length on the added sun room I've posted about here a couple times, which I replaced this past weekend myself) but location wise several stretches are a real MONSTER. Quite high up and over very uneven, ladder-unfriendly ground. I haven't gotten an estimate yet, but I wouldn't be the least bit surprised, given the nature of the house, if it wouldn't be well over $300. If I did pay someone, I'd have to go up there at least once to make sure they did it right (or AT ALL) anyway. I have no idea if this thing works, posted about it as much out of curiosity/amusement as anything else, but if they had a complete money back guarantee, I'd probably give it a try.
Dan
>Dan, I installed GuttaGard (or Gutta Guard) on my gutters about five years ago. I told my neighbor about it ten years ago. (Then waited to see if he liked it) It has worked nearly perfectly. cost about $100 for about a hundred feet. Took a couple of hours to install. Have not cleaned the gutters since.
Occasionally in a really heavy rain, they over flow, but that does not really bother me. If they over flow twice a year, they will do little or no harm. If they overflowed every rain it would be different.
They are the type that is made out of a strip of aluminum that has no holes or slots and the water curls around the rolled edge into the gutter and the trash fall off. A do it yourself version of Gutter Helmet or the Englert system.
The Robot looks like it might work if you ran it once a quarter or once a month. I doubt it would do much if you ran it in a gutter packed with a year's worth of crud. OTOH, I would almost rather just clean them once a year than run the robot four times as often.
Another option is Flip Clean gutters. Your Gutters sit on hinged brackets. Once in a while you take a long stick (they provide) and turn them upside down and empty them, then turn them back up. Very satisfying. You get to actually see that they are empty.
Dan Mitchell
>Barry - Thanks for the reply. I know the kind you mean. I've also seen the "dump" ones.
The guard system in the link is marketed heavily around here, is supposed to deal especially well with the large number of conifers in the area. Not sure how much it costs to install, probably not cheap, don't think it can be done DIY.
If I could pick up one of those robots at a local store & try it with a full return option, I'd give it a shot. Emailed the manufacturer about that, so far no reply.
Leaf Filter
>Dan, I have not seen the one you posted. Not sure it's on the market here in the east. (The joke: Move from the west coast to VA and set your watch back fifty years.)
I would want to talk to people that had used it for about five years. I would be concerned that crud would stop it up over time and that unless the top of it were well sloped the big stuff would just sit on top of it, forming a dam.
I watched the "demonstration" of the robot on This Old House Hour. Not very impressive. They laid a new piece of gutter on the work table and threw in a few dry leafs. (leaves?). The robot did not seem to do a very good job, leaving a significant percentage of the stuff behind and it seemed to get stuck under one of the hanger bars. It clearly was not getting very good or reliable traction. Looked to me like you would have to run it two or three times. I would want to play with it in my own gutters before I bought one.
The flip clean type bothered me at first because they dump the crud on the shrubbery, but then I realized the robot would do the same thing. I was also concerned the flip ones would dump the stuff on my head, but they don't. I played with one at somebodies house and the stick they give you is long enough that you are well back out of the way.
