P-C 4212 DT Jig question
Nat Robison
>I got a new PC 4212 dovetail jig around Christmas and finally got it out of the box today. On the third try, I finally got something resembling a decent through joint.
However, the tails are too short (or are the pins too long??!). As far as I can tell from the directions, the depth of the bit is the same for cutting tails and pins. Any thoughts?
Re: P-C 4212 DT Jig question
Carol - now in NC Nebraska
>Double check the distance of the template from the front edge of the jig. This is sort of critical. :)
Same Thoughts
>Good Morning Nat,
There are alignment lines on the template. Match the edge of the stock to the appropriate line. Don't feel too bad, I've kept my failures private. :<) Read, then follow the manual stept by step.
George
Response
Nat Robison
>As far as I know, I was lining up the vertical piece with the lines on the template and butting up the backer (horizontal) to it. Carol mentioned measuring the distance from template to jig but nowhere do the directions mention the need to measure anything........just use the lines on the template.
I'll take a few more shots at it. I can quickly sense another router purchase in the future. Cutting these DT's with a single router is tiresome. Can a little palm-sized router handle this duty?
Can anyone confirm that the bit depth is the same for tails and pins?
Re: Response
>Good Evening Nat,
You are sure you are using the correct template? and the correct line on the template? The 4212 comes with two aluminum templates. The 1st was stored on the jig, 2nd was stored within the bottom piece of styrofoam. The correct template will also feature a preset bit adjustment guage. Use that to set the depth of your straight and dovetail bits. I am lucky enough to have two routers, so I set up one time and run the whole job. It is convenient but not absolutely necessary.
George
Re: Response
Nat Robison
>The templates are correct but I moved the depth gauge from its initial setting, possibly thinking that you could vary it. I'll run some more tests but basically, if you're using 3/4" stock, should the bits extend 3/4" below the bottom side of the template? 1/2" for 1/2" stock, etc?
Re: Response
>Good Evening Nat,
Set the bit according to the guage. The thickness of the stock will position the template so the router cuts at the proper depth. Re-read and follow closely the operator's manuel and you should be oaky.
George
Pat Barber
>Just for the record, I have had many problems with this jig.
I can make through dovetails, and sliding divetails, but I
can not get a decent half blind that will fit properly.
It will go together with a hammer but I think that is incorrect.
I have tried three of these things over the years, and every
single one is royal pain in the wazoo to get correct.
