air drier
Howard
>I have a small Makida oil lubed compressor feeding a rubber hose air distribution in my shop. What would you recommend for drying the air coming from the compressor?
The air is not used for spraying paint.
Thanks
Howard
air drier
Howard
Thanks
Howard
Re: air drier
>You really have two "inexpensive" choices.
An "ambient" air drier (essentially a filter) or a inline desiccant air drier. The big ones - refrigerated or desiccant towers are more expensive than your compressor!
The "ambient" is probably going to be somewhat less "bother" (no changing out of desiccant packs). It will get most of the water out. You could put an ambient and a desiccant in "series" for critical applications.
In my old job, we used a tower system to get down to a dew point of -40 F for the general air system and we had some secondary systems to get the dew point down to -80 F or so for particular applications.
Why bother?
Tim Greif - West of Chicago
>If you're not using air for spraying finish, why do you think you need to dry it? Most woodwork air tools are not heavy consumers so the moisture caryover should be minimal. I have a simple filter/condensate bowl that never gets any moisture in it unless I've been doing some continuous heavy grinding or sanding with a rotary tool. I've sprayed a motorcycle and a boat with very good results and no moisture problems.
