OT - Stupid computer monitor trick - Fixable?
Denis Ch�nard, Orl�ans, Ont.
>My kids were in the dining room playing with magnets and experimenting magnetism. I told them I'd show them a trick that I shouldn't really do, that is, moving a magnet in front of the monitor (good old CRT) to show them how magnets affect a computer display. They found that it was very cool, then before I could stop him my oldest stuck a magnet right on the monitor itself (I was keeping mine at a distance).
Now I have a darker spot on my monitor... I tried degaussing it a few times, helped a bit, turned the monitor off a few times "to let it rest", but I still have a darker spot on the screen.
Is my monitor toast, or is there something I can do to return it to normal?
TIA,
DC
Re: OT - Stupid computer monitor trick - Fixable?
ssteveee
>Probably it's toast. But since you don't have much to lose, you can try going at it again with a magnet and try to minimize the damage. I had a fair amount of success doing this when a friend's kid (seeing a pattern here?) figured out the magnet from a car speaker would do weird stuff on a screen. Try moving it in a circular motion around the bad spot, you'll see how it affects the light. Good luck.
JohnKJordan in East TN
>Denis,
It sounds like you have a magnetized spot on the shadow mask, which is right behind the phosphor inside the tube. If magetized, the electron beam will be deflected away from the phosphor color dots. Usually mild magnetization results in a fairly broad purplish area on the monitor. If the spot is small and quite dark, perhaps the problem is more severe. (I don't have experience with that.)
You can demagnatize a moderately affected CRT several ways. I have a degaussing coil which is the easiest, but unless the shadow mask is damaged, you may be able to fix a magnetized spot on the mask with the same magnet. I've demagnetized several over the years with this method.
Take the magnet and start swinging it back and forth as you approach the monitor. Keep it moving all the time. When you get close enough, you will see the colors sweeping in the magnetic field. I approach and "paint" the the discoloration away, then back away from the screen while continuing to swing the magnet in the air. It may take a few trys, but I've always been able to return the TV or CRT to useful condition. (I don't remember one where a powerful magnet had been put directly on the surface, however.)
If you have a highly magnetized spot, this may not work of course. You might also take it to a TV repairman and see if his degaussing coil will work. The mask can also be damaged physically by shock. I wonder if it is fragile enough to be damaged by a powerful localized magnetic field. Again, I have no experience with that.
BTW, my oldest son gave me a pair of magnets for Christmas that I'm almost afraid to play with. They are supposed to pick up at least 120 lbs. There is a warning not to stick one on a flat steel surface without some means to mechanically pry it off or slid it off an edge, or it will be there for good! I've played with plenty of supermagnets over the last 20 years, but these are the strongest.
Jason Roehl in Lafayette, IN
I did this once...
>...to a TV. I didn't stick the magnet directly to the screen, but I had it pretty close. At least it was up in a corner. We didn't do anything to it, and it eventually went away, but it was quite some time, like maybe a couple years.
I'd give the other suggestions a go, first.
Jason
Play with it.....
Tim Greif - West of Chicago
>A little over a year ago, my home took a lightning hit in the roof. Among other things, two TVs were affected. A 19" with a big color smear down the center, and a 13" with a color smear in the corner. Not knowing these things could be fixed, I put the 19" out for the trash collector. But I continued to use the 13" until one day I asked on this site if anybody knew if there was a fix. Turns out you can degauss a monitor with a strong magnet. Not sure who advised me of that but I'm still thankful. Fixed the 13" and now I'm convinced I probably made a mistake tossing the 19", since I probably could have fixed that too.
I have a dial indicator with one of those magnetic bases that's very strong. I simply slowly approached the surface of the screen while keeping the magnet in sort of circular motion. You'll see the color smear change as you do this. It take a while and a few attempts to completely erase the smear but it worked for me. I'll admit, it looks like you're doing some sort of voodoo at the screen, so get some people to watch you for some laughs. Good luck. I'll bet it works if you have a good strong magnet.
One other thing I forgot to mention.....
>When doing the magnet motion, you're going to get it pretty close to the monitor surface to have any real effect. When you back the magnet away from the monitor, you want to do so very slowly, much like when we used to demagnetize tape deck heads.
wayne in Topanga
>Television repairmen have degausing coils that work well for demagnetizing CRTs. Also, Radio Shack used to sell bulk audio tape demagnetizers that should also work for solving your problem.
Good Luck,
Wayne
