>Okay, Okay this is really a stealth gloat :) I recently built a piece of furniture for my brother, and in return for my services, he bought me the Domino. It looks real cool, but it doesn't provide much in the way of instruction. Anyone know where I can get educated on the finer points of how to use this nifty device?
That's a Gloat AND a Neener. Though the DOMINO looks like a biscuit joiner/cutter -on steroids - it AIN'T. This is a revolutionary woodworking tool that will probably not only change how you join parts, but also will put projects on your To Do List you previously probably wouldn't even consider.
Yes, the "manual" that comes with the DOMINO, or at least did, SUCKS! Fortunately much of what Festool didn't provide has been filled in by owners - like Rick.
The DOMINO has one fixed built in preset - the distance from the inside of those little retractable pins and the centerline of the mortise, and four other "fixed options" prests - distance from mortise centerline to bottom of fence, depth of mortise cut, length of mortise AND width of mortise. (Think of a plunge router's depth of cut turret). These things make set up a "Click and Go!" process and make recording of set ups for future use simple and easy. Loosen the fence lever and lift the fence. Click in a distance Fence to Mortise Centerline (actually, the numbers on the "stepped stops" are HALF the distance from fence to morotise centerline and NOT the distance from fence to mortise centerline), lower the fence to the stop and lock it down. Pick a cutter bit and install it - easily and quickly - and that's done. Click a depth of cut and that's set.
There are a LOT of combinations of the presets - to many to try and go through here but the link below hopefully fills in some of the blanks.
Have fun with the DOMINO - and please share your discoveries.
charlie belden
Rick - you forgot to point him to the Festool group - http://festoolownersgroup.com
