Re: Dumb jointer question
Chugbug
>Contrary to how puzzling it may appear, the levers work very easily. IMHO, As easy as rotating wheels (on a small table). Obviously, with the wheels, you turn the wheel or "crank it" with the mounted handle. With a LEVER, you lift up to raise the table; and push down on it to lower the table.
How they work (basically)? On the wheel models, the wheel rotates a worm drive to raise and lower the tables. One a lever model, instead of having the worm drive internally they basically dependent on the "greased pig" method of needing to have the "ways" (the channels on either side of the base of the table) greased well for the table to move; and friction to keep them from moving too much.
The main differences (IMHO)? 1. Most folks believe the rotating wheels are more accurate to adjust, which is one reason why you see wheels on more expensive models. The other reason you see them on larger more expensive models I would think is because the wheel (and its internal mechanics) are needed to move a larger table whereas with a smaller / lighter table (6" and 8" jointers) the mfgs can get away with less interal mechanics and the simple "greased pig" slide and lever to move the table.
On some models, as on my 6" Yorkcraft jointer, you may see both. On my YC-6J Yorkcraft jointer, I have a lever on the infeed table, and a wheel on the outfeed table (up until last year Yorkcraft jointers were made/sold by Wilke Machinery in York, PA). I guess the wheel is on the outfeed table because that table needs to have a more fine tuned adjustment in order to opperate properly.
Mine is just coming up on its 4th birthday this week (purchased Jan '04). After using it for the past four years, using the lever has become second nature, and pretty easy to raise and lower the table with it. The table is tight enough, but loose enough that when I pull or push on the handle, the table moves where I need it. Not really any "fiddling around" is needed to get the table set where I need it contrary to what some people suggest). Maybe has to do with having the correct adjustment.
I've been satisfied with my purchase. If you are buying a small jointer (6"), I don't think getting a lever over a wheel is an issue. Not sure if it is a factor on an 8". May be iffy. But on larger models, I'd think wheels would be a must.
Hope this helps...Chugbug
PLEASE NOTE ---IMHO--- These comments are MY-OWN Honest Opinions! Others certainly MAY vary.
