botched Poly finish-- too late to fix? Advice?
Dave Huber
>I think I may have goofed up badly.
I recently finished a coffee table in white oak. I applied Jeff Jewitt's recipe for Mission finish, which I have used before, with success.
Specifically: Aniline Dye, then BLO, then shellac-2 coats, then glaze.
Looks great.
However, this time, finished with 2 coat of WB Poly. I have young kids, and the Poly is a necessity for everyone's survival.
I think I made a crucial mistake, which I hope is not fatal.
I put the table "in service" after about 18 hours after the second coat of poly.
I noticed a white blush under the finish after a warm (not hot) dish was on the table for a short time. The white dissipated, but the finish is a little dull in that spot. Nobody else might see it, but I do.
My questions:
1) if allowed to dry more completely, is the poly likely to prevent further occurrences of the white blush? I have treated other surfaces coated with Poly MUCH more harshly than this incident without any problem.
2) can i safely scuff the surface and re-coat with poly, or is it too late?
Thanks for your help.
Dave
Re: botched Poly finish-- too late to fix? Advice?
Dick Coers
>I'm also suprised with the blush mark. That's very unusal with WB poly. Did you use a WB glaze? Maybe all the color work might be incompatible to the poly. Do you really think that it needs another coat? Can you wait another week and either use abralon pads or polishing compound to adjust the sheen over all the table?
If it does need another coat, it's my feeling that if you scuff it with 320, that will give it enough bite to hold on. Good luck.
Howard Acheson
>It is a basic rule not to put anything hot or cold on a newly finished surface. Waterborne acrylic gets dry to the touch in about an hour but the secondary coalescing process that produces the protective film goes on for a couple of weeks. Until that process is completed, the surface is susceptible to moisture penetration and to abrasion.
Second, you have lots of coats of various finishes on your surface. The one that is a particular problem is the BLO. How long did you give it to cure? If less than 5-7 days, it will be affected by heat. It takes oxygen to cure BLO and the shellac coat is a very good barrior oxygen which means it may take even longer for the BLO to cure.
So, the bottom line is to let a finish fully cure before subjecting it to hot or cold. After all, even after it's fully cured, trivets and coasters should always be used.
