repairing chip in granite
Howard
>I have a backsplash that has a piece missing and I wanted to know if there is a way to build it back up. Appreciate your suggestions, it's a really nice looking piece of stone.
Re: repairing chip in granite
>Howard, the factories use epoxy to fill the stone. If the piece is gone, you're left with trying to match by pigmenting the stuff.. Since your piece is vertical, you'll have to seal it with tape and then open a small hole at the top of the tape to pour into the void. Then you go into grind and polish mode. Contact a stone guy (not stoned guy) in your area for tips and materials.
mm
Re: repairing chip in granite *LINK*
Mike in VA
>Try this link. I used the Poly-Akemi 1000 knife grade for some joints on my granite counter top. Got the tints from them too. This product hardens very quickly and adheres to the stone very well. The color matching can be tricky. I tried several "recipies" first, until I found one that was OK.
http://www.granitecitytool.com/showitem.cfm?itemnum=364&catnum=2&pcatnum=0
Howard
>Thanks - I will give them a call
Howard
>Thanks mark-if I can't do it myself reasonably, I'll call my stone guy
