Rookie Question - What type of Plywood?
Cody Lewis in LV
>I'm finally going to do a project that my wife isn't going to make me paint white. I'm actually going to get to stain and finish this one, so that means the wood type matters more. I'm making a large cabinet of sorts and I think it'll be best to use ply. So here are my rookie questions:
1. Do they make ply with finished sides in all sorts of different wood types? I see birtch and oak a lot, but I also see "iron on" laminate strips for the edges made out of several wood types so I assume they make ply of those materials too.
2. Is there a particular type that's considered nicer than the others or is it just personal preference? I plan to do some type of dark stain in case that matters.
3. I've never attempted to finish the edges of ply with finishing strips. Is that something I should really study up on, or is it pretty straight forward?
Hopefully these are easily answered and I'm not opening a can of worms. As always thanks so much for the help.
Re: Rookie Question - What type of Plywood?
ScottS
Most plywood comes unfinished, but there are a number of wood species available. My local specialty lumber yard has several varieties of Birch, Maple, Cherry, Oak, and Walnut available. They may also have Mahogany. An there are several varieties of wood I've never heard about (e.g. Agathis). If you've got enough money, you can probably get plywood in just about any wood species: bamboo, zebrawood, etc.
Be prepared for sticker shock: hardwood plywood is significantly more expensive than the stuff you're used to seeing at Home Depot! Also, keep in mind that nothing says that both faces of your plywood have to be the same species or quality. Depending on what you're doing, you might only need one high-quality face. When I'm working with cherry plywood, I often buy what my local lumber yard describes as "shop" quality. It tends to have one face that's good to excellent quality and the other face is just decent. The price is significantly less than buying plywood with two high-quality faces, however.
It's mostly down to personal preference. Many people like Oak. I don't. My favorite woods are maple and cherry.
It's pretty easy, but that doesn't mean you shouldn't practice first! The big thing to watch out for is staining. I've found that edge-banding often takes stain very differently than the plywood face it's designed to match. You might also need to experience trimming the edge banding to the exact width of the plywood; I went through a couple of different tools until I found one that gave consistently good results.
Cody Lewis in LV
>Great advice. Thanks.
>I can answer some of your questions.
1. Do they make ply with finished sides in all sorts of different wood types? I see birch and oak a lot, but I also see "iron on" laminate strips for the edges made out of several wood types so I assume they make ply of those materials too.
Yes - they do. My "favorite" lumber dealer carries Red Alder, Natural Birch, Red Birch, White Birch, Aromatic Red Cedar, Cherry, Hickory, Knotty Pine, Mahogany, Maple, Red Oak, White Oak and Walnut as well as Baltic Birch, Poplar and Lauan. They also carry the corresponding edge bands.
Veneer core plywood is the type that I like the best - it is made with veneers of other woods faced with a veneer of the "signature" wood (i.e. walnut). There are various grades of hardwood plywood. Shop grade is the least expensive which means there are some defects. Bear in mind that the better the faces of the plywood, the more expensive it is. A Cherry AA-1, plain sliced veneer cut runs about $130 for 3/4" while a shop grade runs $92. A Maple AA-1 would run about about $120 for 3/4" while a shop grade would run about $60.
If you aren't too particular and just want to try a project, consider Poplar plywood - it is much cheaper.
As far as edge banding, I don't know - I usually use a strip of the corresponding wood or a face frame.
Thomas S Stockton
>Cody,
1- If your talking about plywood that is prefinished, yes it does come in different species oak,cherry maple and birch come to mind there are probably more it really depends on what your hardwood dealer can get or has on hand.
2- plywood is sold by grade. one example is "a1" which has an "a" face and a "1" back, this is usually the highest quality material that a dealer carries. On the higher grades they will have different face grains such as flat cut, book matched or planked matched. You can also ask about core material some examples are MDF, veneer core or pro core. A1 ply cost around $100 a sheet or more another option is shop grade ply which is usually the same core but has some mild defects and sometimes is nicer than the good stuff there are two ways to get shop grade ply one is a high grade panel that has been downgraded for a defect or there is manufactured shop which around here is usually C3 grade. depending on species this costs about a third less. The A1 is better but might be overkill for your project, I think your best bet is to go and look at what is available in your area.
3- finishing strips are called edge-banding and there are many ways to do this, I think what your talking about is the iron on type that comes in rolls. This stuff is pretty easy to use and you can use an iron to apply it and a specialized trimmer works well to trim the edges.
A brief rant on buying plywood and lumber- DO NOT GO TO HOME DEPOT LOOKING FOR QUALITY MATERIALS, they generally sell garbage that is fine for fixit jobs, but your best bet to find high quality materials and help is to find a good hardwood dealer that doesn't mind selling to hobbiest. They will also be much cheaper in the long run although you might have sticker shock at first. They will also carry some hardware. The drawback is that they usually are not open on weekends but do open early weekdays so you might sneak in before work.
I've included a link to one such place although it is not near you (I think) it will give you a good idea of what is out there and they have a link to the NHLA that can better explain the grading critia for both ply and lumber.
This might seem really overwhelming at first it isn't that bad just keep asking questions.
Tom
Thomas S Stockton
>Don't forget to use woodfinder to find a local source
Edgebanding
>For a quality job, I would advise you to rip 1/8" strips of solid wood for edgebands. The iron-on stuff is made of veneer, and there's no way to ease the edges without cutting through it and revealing the core of the plywood. So, you have to settle for sharp, square edges that are vulnerable to dings and dents and splintering. Solid wood edgebands are more work, because you have to rip them from solid stock, then glue and clamp them to the edges, then trim them with a router or hand plane, then round them over or chamfer them -- but you end up with a much more solid and long-lasting panel, with friendly edges, that resists abuse much better.
Also, you may find cabinet ply at lumber dealers, but the best prices and selections are at plywood wholesalers. As a rookie and a non-professional, you may have a hard time getting them to sell to you. If so, try looking up a local custom shop or kitchen cabinet fabricator and see if they will piggyback your order on their next shipment from the wholesaler.
Ellis Walentine, Host
>I agree with all of the above and I would point out one more thing. Modern veneers are unbelievably thin. I have pieces of plywood where the face veneer is so thin I can't see the edge of the face veneer. I can sand through it in nothing flat. Literally with a piece of 120 grit paper and about four strokes. Be very careful. Do not count on sanding off boo boo's or layout marks.
