Log Weight
Howard
>Having a large red oak cut down that I will probably haul to a mill for sawing and drying. Anyone have an idea of the weight of a 2 1/2 foot wide by 10 foot long red oak log?? Thanks
Log Weight
Howard
Re: Log Weight
Gary Evans Tallassee, TN
>Howard,
If you go to www.woodweb.com, you will find a section of calculators. One of those will figure the log weight for you.
Gary
Re: Log Weight *LINK*
JohnKJordan in East TN
>BTW, the Lumber and Timber Calculators are under "Resources" in the left-hand column near the bottom of the page.
http://www.woodweb.com
Re: Log Weight
Stephen Kirk in Quakertown, PA
>I forget the numbers from when I milled up a bunch of red oak logs. I can say, though, heavy as heck. I have a book with the relative weights at home if you don't find out before my work day ends.
Thanks-Just Went to it Now
Howard
Re: Log Weight
Howard
>How did you load it to get it to the mill?
Re: Log Weight
>Howard,
Butting in, I've loaded a bunch of logs on my trailer and flatbed truck. (I have a sawmill behind my barn.) I use the front end loader on the tractor where possible, but some logs are too heavy and sometimes the tractor is not available.
IMO, the EASIEST way to load a log too big to lift is by using ramps and a chain or cable. Lay some heavy ramps against the side of the trailer or truck bed. I use a couple of 10' I-beams I happen to have laying around. (Position the truck and ramps so the ends are as close to the log as possible.) Fasten a chain or cable to the center of the log and wrap it around the log multiple times. Sometimes it is necessary to dig a short trench under the log to get the chain under. Put the long end of the chain over the truck bed and pull it with a comealong, winch, tractor, 4-wheeler, some strong men, or whatever. (Note that the chain must be wound around the cable such that pulling the other end rolls the log up the ramps.) The force needed to roll the log up even a steep ramp this way is surprisingly moderate. Be sure to have blocking or something in place to chock the log when it gets to the top of the ramp so it doesn't roll across the bed and off the other side!!
BTW, if I am loading onto my trailer, I first lay down a couple of railroad ties to keep the log above the trailer fenders so I can roll it off again. If you are taking logs to a sawmill, this is probably not necessary since they should have equipment to unload even large logs.
About a ton. Green wood fresh off the stump
Forrest Addy
>About a ton for that size log. Green wood fresh off the stump barely floats in most species. 55 lb per cu ft is a good rough figure. Then there's taper and the other complications. Don't mill it too wide or too thin. Red oak can get pretty wavy when it dries.
Re: Log Weight
>I had mine sawn in place (sawyer came to the property). We just had to move things around with some peaveys. Put a 2x4 under the middle of log and you can pivot a 1/2 ton monster around with ease.
I've rolled smaller logs (like, still 500 lbs or so) onto a pickup truck using ramps, peavies and a couple of strong backs. All the techniques mentioned above would work fine too.
I just got a line on some maple logs which I'll probably rent a trailer for. Some ramps with peaveys and a come-a-long should work fine.
Re: Loading & Hauling
Joe in Tallahassee FLA
>As for loading, I like the previous response but have never tried it that way. However, I would be afraid to support a log the size you described up on the sides of my trailer.
I have loaded them by using a comealong and chain to drag it up a couple of ramp boards extending off the back of my trailer. You need a tree to attach the chain to. Don't attach a chain directly on the pulling tree as it will seriously damage it. Use a wide strap.
If you will need to unload without a tractor, make sure you load the log on top of some 2x4' running crossways in your trailer so you can get a rope or chain around it. Back up to a strong tree, hook the log to the tree and drive out from under it.
You really need a cant hook or peavy for working with logs like this.
As for driving, unless your trailer is real beefy, be carefull going over dips, like those often occurring at bridges. I bent a trailer axle on one once.
Above all, BE CAREFUL!
>>...I would be afraid to support a log the
I forgot to mention, I use a heavy duty dual-axle trailer made for hauling heavy equipment. I would never try loading logs on one of my smaller trailers. However, I far prefer to haul logs on my flat-bed truck (1975 vintage, 12' bed). It's easier to maneuver and the logs roll off nicely for unloading.
Easy way out
>A fellow I know recently wanted to have a large log taken to a mill. I suggested calling someone with a tilt-back car carrier. They can winch your log up the ramp, tie it down and deliver it for you easily. I don't recall how much he paid to have it moved, but it was a bargain compared to the effort and angst of doing it himself.
Ellis Walentine, Host
Re: Log Weight
Howard
>Thanks everyone - I'm checking to see if I can get someone with a portable mill to cut the logs on -site. otherwise I'll consider taking them to the mill provided I don't end up crushing myself!!
GREAT Idea!!
>That one getsw put on a sticky right above my sawyer's name.
