Newest tool gloat
Newest tool gloat
Newest tool gloat
Don in Northern Arizona
>I have been reading the shop safety articles in Popular Woodworking, and suddenly had a "Doh!" moment. In addition to protecting my digits and lungs, maybe I should do something to protect the building. 30 bucks.
Don
Re: Newest tool gloat
>Good Morning Don,
I couldn't think of a more desirable object in any shop than a fire extinguisher. They might hang on the wall without use for years. However, there will be that one time when you must react quickly, and you need one in your hands right away. A few months ago we had such a need, and like you we were prepared. We got away without any damage at all. Had the fire not been put out, it could have put a real dent in our happiness.
George
Bruce, a MN Galoot
>After far too many years of not having one, my son gave me a fire extinguisher for Christmas. I don't really know why I didn't do it before, but it sure provides that first level of protection I haven't had.
Bruce
AMEN ! Makes me want to . . .
steve mackay
>go get another just for the heck of it. Sure I can find someplace to hang it. Never had to use one of mine but i know they're there and get a warm fuzzy. You do everyone a service with this one ! Heads up !
Gloat, Indeed
>For your diligence and smarts.
I have two in the shop, one in the kitchen, and 2 in the garage. Yes, there is good reason I keep leaves blown OUT of my garage.
mm
good reminder
Mike Schwing from Md.
>I have two extinguishers in my basement but none in my basement shop, where the fire is probably going to start. The time it takes me to run to get one of them might be the diff between a little and a big problem. Time to move one into the shop.
Lee Schierer - McKean, PA
>Yep, good idea. I've had one in my shop for years right by the door. You also have to check them periodically to insure they hold their charge.
Lee
Stephen Kirk in Quakertown, PA
>Great idea. Which means I should go out with all due haste and buy one.
JohnKJordan in East TN
>Good idea!
One thing: when I was shopping for fire extinguishers a couple of years ago, I found only cheap, non-refillable extinguishers with plastic valves at the local hardware and big box stores. These are intended to be disposable so you will buy more later (and feed our poor starving landfills).
A look in the yellow pages led me to a professional fire extinquisher company who sells and services industrial models by the thousands. The prices were quite reasonable, the quality was higher (e.g., metal valves instead of plastic), the capacity was higher than the consumer models, and the units can be serviced and refilled in the future. I bought them for the house (utility room and kitchen), garage, shop, and barn.
where to locate it......
Bill Tindall, E.TN
>We had a presentation by a fire expert and he said to put it between the source of where a fire might occur and your escape route. So for example you don't put it next to the stove but between the stove and the exit door.
>John,
This is very true. The one we have in the house is a cheapie that can't be refilled. This one I bought from a company in town that provides fire protection services for businesses. I told the person I spoke to the size of my shop and he recommended this one, a 5 lb ABC unit. It is serviceable and I will take it back next year and get it checked.
Don
Re: where to locate it......
>Bill,
Good point. I located it by the door to the breezeway which leads to the house. That way I can defend the house, and if I spot a fire or hear the smoke alarm in the shop while I'm in the house, it is easier to get to. My flammables are on the opposite side of the shop, as is the grinder (a great little fire starter).
Don
Jesper, Denmark
Re: May you never need it, but...
Jesper, Denmark
>Remember to take it off the bracket every 6 months or so and shake it up, so that the powder inside stays fluid.
Those ABC powder types are very effective, but Boy, do they ever make a mess if used.
David Yoho
>Good on you, Don. I've had two hanging in my shop since day one. Hope I never need them!
David
