Vacuum Pressing Question
>I just bought and set up a Vacu-Press system this weekend. I did a test panel and it was a success. But a question....
The manual suggests making caul panels when pressing veneers. What if you don't use a caul and simply cover the applied veneer with a non-stick barrier? Just curious (and potentially lazy).
Thanks in advance.
Tom
Re: Vacuum Pressing Question
Norman (Ottawa, Ont.)
>What comes to mind for me Thomas is the need for uniform vacuum or pressure distribution of the area you are veneering, otherwise you're directly at the mercy of the vacuum bag.
Also,, if you simply draw a vacuum directly from the veneer over substrate without a caul or platen, the glue will mostl likely be drawn through the veneer and you also have much more likelihood of any small sawdust or anything sitting on the veneer to telegraph through and vice-versa.
I really don't think you can get an effective glue-up without a caul.
The caul or platen acts to distribute vacuum evenly.
Norman
jcousins
>when i can i use platens on both sides of the piece being pressed - but have often used a platen on the lower side and some breather mesh on top -which essentially uses the bag as the upper platen - but insuring that all the air gets out - have not had any problems.
jerry
Jesse Cloud
>Ditto on breather mesh. A caul is handy if you are doing the same operation many times. Cauls are next to impossible with curved work so I always use mesh on that.
You can get the mesh from joe woodworker.
Thanks Guys!
>Thanks for the responses. All were helpful. Looks like cauls in some form are a good idea. I'll probably order a mesh too and use that as well. Looks like the mesh will save me some time and materials when it's the appropriate choice.
I appreciate the input!
Tom
