Scribing to stone on the diagonal (w/pics)
David Eisan
>Hello everyone,
I have been working on the flooring at my house for the last few weeks and I have come upon a very challenging section. I have a stone fire place that needs to be floored up to. The flooring needs to be scribed to the stone, a task in itself, but add to that that the flooring is being laid on the diagonal.
At first I tried scribing with a compass, that didn't work. Then I tried an expensive stainless steel fine wire profile gauge, didn't work well. What worked the best was an inexpensive Samona plastic profile gauge. This was because of it's "low" profile that allowed me to take a profile at the correct position/height easily.
Even with the profile gauge, I found it was best to transfer the profile from the profile gauge to a piece of cardboard and test fit the cardboard template. Trimming cardboard with a pair of scissors is much easier than running to the bandsaw in the garage with a piece of flooring. And, cardboard is cheaper than flooring...
Once I was happy with the fit of the cardboard template I transferred the profile to the flooring. The flooring I am using has 10 coats of finish on it, and I cannot see a pencil line on it for the life of me. What I ended up doing was colouring in the end of the board with an old school grease pencil/marker, and then when I transferred the profile, the normal pencil removed the grease pencil marking my line. The grease pencil wipes off with a paper towel.
I cut the profile on my little 14" bandsaw using a 1/4" blade. I have been meaning to get a magnetic lamp for my bandsaw, but a Makita flashlight does a great job.
Think it will fit?
Good Enough for me!
This has been one of the hardest things I have done in a while. Twenty One boards scribed, three more to go....
Thanks for looking,
David.
Every Neighbourhood has one, in Mine I'm Him
Re: Scribing to stone on the diagonal (w/pics)
Shudder!
Rod Peterson -- Ormond Beach
>Reminds me too much of the 1800 ft^2 of engineered Brazilian cherry I helped my son-in-law put down at their house a couple years ago. Glue-down with a PL glue. Yikes!
Anyway, we didn't have any scribing issues like that to deal with. It was bad enough dealing with that glue. One thing I did learn was that a citrus cleaner made by Bruce for their flooring products will actually clean up Sharpie™ marks. Consequently, we Sharpied™ our way through the project with impunity. I stole the leftover from them for my inevitable future Sharpie™ mishaps.
Very nicely done, Dave.
Rod
Charlie M
>I had similar problem going around a brick fireplace in my family room. I took the lazy way out and ran a quarter round I'd stained to match around the edges everywhere in the room.
Wow! Nice work!
Tony - Memphis
Cleaning up Sharpie marks
Henry (Raleigh NC)
>Rod - Most alcohols will clean up Sharpie 'permanent' marks. Two that you would very likely have access to are Isopropyl alcohol and Denatured alcohol. Isopropyl alcohol also is known as isopropanol and it is the primary constituent of drug store 'rubbing alcohol'. Although I have not tried it, I would expect that de-natured alcohol would work; this is about 5% Methanol in ethanol and it's likely in your shop for thinning shellac). Although it would be a waste of high grade liquor, I would even guess that any high proof distilled spirits would work.
So as long as you are not dealing a shellac finish, this should work; most wood finishes and paints besides shellac are not alcohol soluble. Of course, I'll add the caveat - first test on an inconspicuous spot. It's good to hear that Citrus-based cleaners also work.
My Experience: We were on a family Christmas visit a few years back. Their dining table was not formal, it was more like a farmhouse kitchen table. It was the center of family life. One of my nieces had done some craft work on that table, and had used a Sharpie that bled through the paper. The marks were certainly distressing to my sister-in-law.
Being 95% certain that their 10 year old table had a polyurethane finish, I told them that with their permission I could clean that in a few minutes. My wife was incredulous that I would dare mess with the finish on their table (being both a woodworker and a chemist, I still have no credibility!). I asked for some rubbing alcohol and cloth; the Sharpie cleaned off in a few minutes, and the resulting cloudy finish in that spot (that nearly sank my dear wife's heart) cleared up a few minutes after that. By that time I was relaxing with a good cup of coffee while my wife hovered over the spot watching it clear up.
Henry W
Pretty slick work !
steve mackay
mwwoodworks
>Very good work!!! I lay a lot of flooring and that is awesome! I doubt a "next time" Will be anytime soon, however instead of the grease pencil, I stick quick release painter's tape where my profile line is going to be drawn and then draw the profile with a sharpie. (pencil works fine too) The tape comes off very easily and has never caused any damage to any of the pieces.
Beautiful floor and workmanship!
Jim Dillon
Definitely an article in there -- thanks!
