For those with Porter-Cable router tables (long) *LINK*
>I've got an older Porter-Cable 698 router table, and have been frustrated with both the fence and the inserts around the bit.
I seem to have solved the fence problem with a Hartville fence (no affiliation, just a fairly satisfied customer; and it was on sale when I got it). I added T-track on each side of the table (track on top of aluminum angle stock, with the stock then bolted to the side of the table), and use that to hold the fence down. I found that, with the Hartville fence I had to get the T-track dead level with the table top, which turned out a bit challenging because the table edge, I discovered, slants. I wound up drilling and filing slots in the aluminum angle for fine adjustment; eventually, I'll drill some holes for roll pins to keep it in place. Were I starting over, I'd call Benchdog and see if they sell the fence for their contractor's table as a separate item.
My impression from the catalog pics is that the newer 698 tables have a far better fence than the piece of garbage P-C used to offer, so this may not be a problem. I've linked to Hartville's fence below, in case anyone's interested.
I decided I had to deal with the inserts around the bit after one of them bounced out while the router was running. No damage to the bit, and only some dings on the insert, but quite some damage to my peace of mind. I spent a while in spare moments thinking about how to fasten the inserts down and decided I needed a "collar" that would accept screws through the inserts. It seemed like a huge hassle, as I'd have to get the alignment just right, and, if I ever wanted the full diameter of the hole, for a panel raising bit, for instance, I'd have to flip the table over to remove the collar.
Then I realized: if I make the collar large enough to use the screws that are already holding the router base under the table, I don't need new holes in the table, and I can remove and replace it fairly easily. The picture below is the result. More pics and how-to's in the next messages.
Hartville's fence
