Is there a way to soften epoxy for removal?
Scott in Eastern Iowa
>Ive got some epoxy on some galvanized piping that I'd like to remove and am wondering if its possible to soften it enough to remove it?
This would be for my 3/4" airline that I have piped into my 60 gal air compressor. I'd like to pipe a few more runs and do it a bit different to suit my current set up needs. Seems I either didnt tighten it enough at the joints or its cheap chinese pipe that has air leaks in it.
Someday I will switch it over to copper, but for now I have this to deal with.....
Thx,
Scott
Re: Is there a way to soften epoxy for removal?
Heat
Paul Woolson
>Try softening it with a heat gun. Standard epoxy will creep at 140 degrees.
and let go at around 320
Michael Dresdner
r payne
>It depends some on the specific epoxy. Since your trying to take it off a galvanized pipe heat is a good first choice. Even if it doesn't soften the epoxy, the differential thermal expansion may break the bond.
If it is one of the heat stable epoxies, it may be succeptible to some solvents. I'd start with acetone and don't forget the safety equipment.
There is always the option of a dremel.
This is all assuming the epoxy bound to the pipe strongly. It may just pop off will a little persuasion.
ron
Ron in Drums PA
>Heat sound work fine, but when you can't apply heat, soak it in denatured alcohol.
Jerry Nicholson
>A little concentrated acetic acid did a great job of softening epoxy paint on my darkroom counter top. Long time back - before darkrooms came on a CD and required a computer.
Jerry
Rick W
>Paint remover that contains metheylene chloride will work as well.Apply a heavy coat, cover with aluminum foil, and let it work.This is assuming you can ventilate the area well.
Rick W
Use some Aircraft Stripper
Jack
>I stripped bunches of epoxy with it. You might have to go to a store that sells automotive paints
Robert Henderson
>I removed an epoxied tool from its handle by putting it in a jar with acetone. I left the handle out of the acetone and put a lid on. In about a week the fumes had loosened the epoxy. Probably straight acetone would work quicker but beware the fumes.
