Using old reefer for storing finish
Johanna
>I just scored a refrigerator that is in beautiful condition but no longer cools. I want to use it to store finishes so they won't freeze -- and so I don't have to keep my workshop heated all winter.
Has anyone here done that? If so, did you use an incandescent light for heat? Exactly how did you install it? What wattage for the main compartment? For the smaller freezer compartment?
I am assuming I drill through the cabinet and use a porcelain fixture.
Re: Using old reefer for storing finish
You can't imagine…
Rod Peterson -- Ormond Beach
>…how many times I had to read that subject line before I got it straight.
Sorry, I can't help, otherwise.
Rod
Randy Johnson Connersville, IN
>I have never tried it but it shouldn't take much of a light bulb. I'd start with a 40 and experiment.You might even want to try a line voltage thermostat to make sure it doesn't get too hot.
How about.....
>...Using old reefer to store reefer. I must be really tired because I wouldn't have picked up on that if you hadn't posted. Normally my warped little mind would caught it right away.
>What you don't want to do is smoke your stash by getting things too hot, and the insulated box is a pretty efficient way to do just that, especially of the door seal is still good. Suggest you use a small bulb, 25 watts will be enough, to keep things from freezing. Then get a simple thermostat so that you can pick and maintain a given temp. I would think 65* should do fine.
>I've used an old freezer for drying wood. For that, I used a 60 watt shielded bulb and I had vent holes that I could cover to "regulate" the heat flow. I used sheet metal to partially cover the holes. I imagine you could use a dial switch and a 40 watt bulb for your purpose.
Carol - now in NC Nebraska
>You can use any lamp fixture. You don't have a moisture issue or a safety issue with your application. Simple drill a hole for the cords and mount one in each the refrigerator and freeze section.
I'd use the lowest wattage bulb I could find for the freezer and nothing bigger than 25 watts for the refrigerator section. Hang a thermometer in there and see how warm things get. When it starts getting too warm, start drill vent holes. Quit drilling holes when you can maintain the temperature you want. Do that for each section.
Don't bother with thermostats. I know your low level tolerance of electrical 'things.' LOL. So keep it simple. May take a little futzing with the number of holes. The smaller the diameter, the more holes you will need, but use any size drill bit you have handy. I'd do 1/2" regular twist bit. Pop a dimple with a center punch and drill away.
If you find you have drilled too many holes, regulate your temperature with duct tape covering a few holes.
If you want it more automated, we will have to schedule another Johanna's Electricity 101 class.
Will that get you going OK?
JohnKJordan in East TN
>>...25 watts
My thought exactly - I would not want cans and bottles of finish to get too hot. In lieu of wiring up a thermostat, perhaps a tungsten light dimmer could be wired in and the bulb adjusted while monitoring the inside temperature occasionally with a thermometer.
Hey, how about using a short flexible heating tape inside with a built-in thermostat? The one I saw was preset to 60F.
I'm confused
Michael Dresdner
>"I am assuming I drill through the cabinet and use a porcelain fixture."
Am I missing something?
I don't recall ever seeing a refrigerator that did not already have a light fixture inside it all ready to take a 25 watt bulb. All you need do is disable the door activated switch that shuts it off when you close the door. If the compressor is still running, simply remove the hot wire to it. The light will probably be wired separately.
avoid making a bomb
Bill Tindall, E.TN
>I trust you don't intend to store anything that will provide flammable vapors in this enclosed space with the light bulb ignition source?
Dave Peebles Lyons, Ohio!
>Hi Johanna,
I am certainly no expert, but I would think that with the insulation in the fridge you might not need any light/heat source to keep things from freezing.
I would just put your finish in and shut the door. :)
Best wishes,
Dave
>>...with the insulation in the fridge
I think the insulation is not enough to keep the contents from freezing if the weather is very cold for an extended time. This may not be a problem in the South.
George (Oxford, NC)
>I have been using an old (very old) freezer for several years. I use a 25W bulb in the bottom. I did gut the motor and compressor.
http://www.ncwoodworker.net/pp/showphoto.php?photo=495
George
Re: How about.....
mwwoodworks
>Don't hide your reefer stash in the fridge man! That's the first place the cops look! What you need to do is double bag your reefer in ziplock storage bags, that way you can't smell anything through the bags. Then you can hide them in various places throughout the house. Also, don't put dryer sheets in the bags to mask the smell, they contain a chemical that acts as a fire retardant. Makes for hard time smoking it later dude! LOL
Gosh this could go on for hours! HA
Nothing like a bad choice of words that nobody will let die! hehe
This is the path to madness!
Dave Bair, Eaton Rapids, MI
Re: You can't imagine�
Bill White
>I finally threw away all my old reefers. DANG IT!!!!!
I just had to do that.
Bill
Work with care
>Some old fridges use flammable insulation - drill with care (and don't use a torch to burn your hole through!).
Also, do you know for sure that the freon is out of the system? If not, you might need to find out how to get it removed safely and without just venting it (illegal in some states, as it damages the ozone layer).
Don't Get Stuck
>Have had several offers of old friges over the years for use as "ovens" [wax and clay drying]. Folks were very nice until I asked if the freon had been removed . . . "Um, what's that?" they asked innocently. I "explained" nicely that all frigs, freezers, A/C units and and such must have their refrigerant reclaimed and the unit tagged by a licensed pro before they can be discarded. Cost is usually about $60-100 depending on the item. "Gee, we never heard of that," was the reply showing proper concern for our ozone layer.
Of course they wouldn't dream of sticking ME with the freon recapture charge just because they felt generous and wanted someone to make use of the old frig, would they?
Nah, they wouldn't do that . . . .
PS
>Make sure the freon's removed from your proprosed finish cabinet before you take it. Otherwise it's an expensive piece of junk. Sorry, should have brought this up sooner.
mm
All joking aside...headin' toward hijack
>Just about everything I know about the subject I got from Cheech and Chong.
When I was in the Air Force is was possible to get a buzz walking down the hall in the barracks most nights but I never thought it was worth the trouble you could get into. Booze was approved and I will admit to consuming WAY more than my share of that.
I am one of a very small minority that managed to come of age in the late sixties and has never taken that first toke.
Re: Using old refrigerator for storing finish
Johanna
>Worked perfectly! Thanks. The refrigerator compartment is staying at 60 degrees with a 25 watt bulb. The freezer compartment has an 11 watt bulb.
Drilled 1/2" holes through the side of the unit and installed rubber grommets to protect the wire from the metal edges. Inside, I used simple ceramic ceiling fixtures. They are mounted on a square of 1/2" thick ash that has a 1" hole in the center and two mounting screws to hold the fixture. The wooden plate is attached to the side of the unit with velcro.
The freon is probably going to have to stay in there until I die and someone cleans out the shop. I presume it is safe since nothing was punctured (except the side of the cabinet -- and I know I did not hit anything when drilling except metal, insulation, and plastic).
