Does anyone have a jig or ideas for a jig to cut the dovetail slots in the bottom of a Shaker pedestal table? Pictures would help if you have a jig already.
I made one this summer and used it with great results. I had it posted here in a Shop shot. Please see the link below, if you have any questions I would be happy to help.
Thanks for the ideas. The turnings are already off of the lathe, but I guess there would be no problem getting it back on. I have lost the original position of the tailstock, but I think I could get close enough.
I am trying to put this together quickly, probably too quickly. I am using a ShopSmith for a lathe and do not have an indexing head, although it would not be hard to rig something up to do that. I guess for this couple of tables I will just do mortise and tennons for the legs. I really do not have the time for the dovetails, and I really do not have the time to mess up and have to start over.
Thanks again. I will print out that shop shot and put it in my project folder so that the next time I pull one of these out to do, I can be reminded to setup the lathe correctly.
>Just checked the Wood magazine website & the article is available to download. Under plans put in search for 'oval table'. The technique in this plan gives you a pattern make indexing blocks to fasten on each end of the turning so you can run the dt's on a router table. It's an alternative to lathe method.
>Rob, I have done this twice, once the way Jim Shaver showed, using a "box" jig on the lathe. Actually got the idea from Norm.
The other method was completely different. Used a router table.
I made a equilateral plywood triangle with a screw hole in the center. The screw went into a hole in the center of the leg. The leg had a ring on it that caused it to sit level on the table, but you could put a triangle on both ends. Then, I raised the DT router bit about an eight inch above the table and flattened a side on the leg on each of three sides. Then I raised it to full height and set the fence on the router table so that it cut its slot centered on each side of the triangle and leg. You can run the leg in both directions to make sure the slot is centered. Use the same bit to cut the dovetails on the legs. I put a piece or two of blue tape at the bottom of the leg dovetails to make them tapered very slightly and they drove home very nicely.
I would post pictures, but it was several years ago and the triangles were so easy to make, I threw them away under the assumption that the next leg would be a different diameter.
>I mentioned the hole through the center. If that is all you use to attach the triangle to the pedestal, it will rotate freely. You must "fix" it on the end with the slots. I uses a tiny brad or two put in so the router bit would miss them. You could use double stick tape or hot glue or just a dot of glue that you would break when the slots are complete. The triangle on the top can "float" and will self align.
I found it useful to cut the tips of the triangles to create a little blunt or flat surface to register against the fence. Otherwise, the point of the triangle slide under the fence and was not very accurate. I used a compass in the center hole and struck a mark on each tip and nipped them off as accurately as I could.
I suppose you realized the flats on the sides were to allow the shoulders on the legs to bear against a flat surface, rather than having to under-cut them to match the cylinder. When you go to cut the DT's on the legs you must adjust the cutter height so that the DT's are very slightly "shorter" that the depth of the slots.
I found it was a good idea to sneak up on each joint. I ran the bit on a scrap to set the height of the DT on the leg. Then I ran both sides of each leg and started creeping the fence in to cut away the excess. My experience was that the correct fit appeared rather suddenly. It would be too tight and I would move the fence the least amount I could and if I ran both sides it would be too loose. When I got close, I would only run one side and check the fit. Then I would run the other side if necessary.
My router table was too small to support the entire length, so the triangle of the top did not work for me. I had intentionally left a bead on the column that was the same diameter as at the bottom. You could build up your table with a scrap that was the right thickness to make the piece sit level.
I have made a couple that turned out to be a little looser than I would have liked. I used epoxy to glue the joints. Turned the post upside down in a vice and coated the slots and DT's with epoxy and Inserted them. To keep them from sagging I put tape gently around the tips of the feet and a big rubber band and packing tape around the "knees" of the legs. I ran tape back and forth from the tape that held the tips of the feet and formed a little "basket". Put a coupe of pounds of weight in the basket to keep the joints tight until the glue set. I also taped all the adjoining surfaces to keep the glue off them. Before the glue sets, look and the layout and see that they are equilateral. You can measure from tip to tip to see if the spacing is equal. Mine were good enough. If they are off slightly no one will know. I liked the epoxy. Used the slow setting kind.
I used three legs, because three legs always sit "level". You could use four, just make the pattern piece a square.
One one piece I did I did not like the look of the bottom of the post. So I drilled a 3/8" hole into the center hole and turned a little drop or finial to hang under the post. It was a nice touch. Turned a dowel on it to fit the hole I drilled.
