>So I have a bathroom door that closes about half way when fully opened. If I place it any where before the half way mark it stays there. So what do I have to adjust to get it to stay open?
Next My front door leans in about ~1/16 inch at the top none hinge side. Any idea on how to fix it? Thanks 45deg F in Kent gota love Indian Summers
>In both cases the door jamb on the hinge side is out of plumb. In the case of the bathroom door, it is probably tilted toward where the door stops. That means it is most likely out of plumb in two directions. The top of the door frame is leaning in. There are two ways to solve this. If there is a large gap between the latch side of the door between the edge of the door and the door jamb you may be able to place a cardboard shim behind the lower hinge. This will have the same effect as straightening the door jamb behind the hinge. Warning, too much shim will raise the door latch so it may no longer latch.
The ideal way is to remove the door casing on the hinge side and remove a shim if there is one behind the upper hinge. The jamb needs to be plumb in both planes for the door not to swing under its own weight. However the door jamb may also be leaving into the room. That means you need to remove or cut the nail holding the top of the jamb in place and straighten the door in that direction as well.
Before trying anything, get a good level (at least a 2 footer and check the hinge jamb for plumb. That will tell you a lot and will show you how much you need to move the door frame.
>It may be what Lee suggested or it could be misaligned hinges. If you have 3 hinges on the door try taking the middle on off. If the problem goes away the hinges are bowing the door when it is fully opened. It swings back to relieve the pressure. If that is the case try reworking the middle hinge pocket and screw holes. If you need to rework the middle hinge attach it to the door, but not the jamb. Open the door all the way now push the loose side of the middle hinge against the jamb and see where it would sit without the screws holding it. Rework the hinge pocket and screw holes so the middle hinge doesn't bind.
>I have used all the tricks suggested so far and a few others.
If it it a three hinge door, you can put two thickness of cardboard behind the lower hinge and one behind the center hinge. Or four and two, you get the idea. the shims don't require you remove the hinge or the screws. Cut strips about a 1/4" wide, loosen the screws and slide the strips in between the hinge and the jamb or door.
You can bend the hinge knuckles with an adjustable wrench. Assuming the screws are sound, just bend the knuckles a little. You can "tighten" the upper hinge by closing the gap between the leafs about a 1/16" or open or loosen the gap on the bottom hinge.
