Talking about veneering...
HC Sakman
>What's your best way to flatten buckled veneers, especially crotches? Glycerine+water mixture? Commercial veneer softener? Just warm water and press... Which one?
Chico...
Re: Talking about veneering...
Darryl Keil Recipe
Joe Burke
>This, I believe, is Darryl Keil's recipe and procedure. I've used it and it works well.
Combine 2 parts white or yellow gule - 3 parts H2O - 1 part glycerin and 1 part denatured alchohol. Mix thoroughly and apply to both sides of veneer.
Place veneer between fiberglass window screen (both sides) and add 2 or 3 layers of newspaper on both sides. Make as many layers as you like.
Place between cauls and press. I used, and believe it was intended for a vac press.
Change the newspaper 2-3 times the first day and leave overnight.
On the second day remove from the press and remove the screen, it's no longer needed, and change the newspaper. Again, change the paper 2-3 times during the day using only some weight on the cauls as a press. No vac bag needed.
Don't skip the second day!! The veneer will be ready to press on the third day and will stay flat for months under light pressure.
Again ... I've done this and it works well. Also, a note at the end of my copy states the recipe came directly from Darryl. Should be a decent source.
Re: Darryl Keil Recipe
HC Sakman
>Sound's like a witch's brew. Why glue??? Perhaps as a "stabilizer"?
Thanks,
Chico...
Lee Grindinger
So it remains flat
Lee Grindinger
>I've used this recipe with wonderful success on veneers that needed flattening, Chico. The veneer remains flat after it's dried because of the glue and months later I was able to work them without issue. I honestly cannot remember if I stained any of these veneers so I cannot confirm or deny problems with the glycerin. I seem to remember someone mentioning staining issues because of the glycerin but I never had a problem.
Lee
>David Marks had an episode of WoodWorks that addressed this problem. As I recall, he used a brew that was similar to the one mentioned by others, but I thought he used some sort of powdered glue (plastic resin?). He used the technique with the screen and newspaper and cause. I took it that the screen was to prevent the newspaper from sticking to the veneer.
I only mention this because I think you can go to the DIY Network website and look it up. I think.
I knew you'd show ...
Joe Burke
>eventually. Actually, my print out of this recipe has your name on it somewhere. I figured dropping Darryl's name would lend enough credibilty. I didn't bring out the big guns. ;-)
Seriously, I've never had a problem with any aspect of this procedure and the veneer is flat and supple afterwards. Very easy to work.
The screen is indeed to keep the paper from adhering to the veneer. The veneer is dry enough the second day to do away with the screen.
So Lee .... Can you even tell it's winter down there?
Lee Grindinger
Can we tell it's winter? Of course...,
Lee Grindinger
>The migratory birds are here, the snowbirds. The beaches are crowded with snowbirds, just yesterday we had fellow beach goers withing 50 yards of us. The locals won't go in the water because it's so cold, only 80. Night time temps are dipping to the low seventies prompting us to turn the ceiling fans off before bed and actually using lightweight comforters.
Can we tell it's winter..., sheesh, whatta question! I'm even wearing a shirt when I don't have to!
Lee
Thomas S Stockton
>Tage Frid's recipe had plastic resin glue in it, if my brain remembers correctly
Tom
