Shop compressor advice needed.
Virgil Johnson
>My old air compressor is slowly dieing.... again. It was pieced together years ago from junk, motor from old dust collector, compressor from an old rusted out Speedaire compressor, tank from an old punch press air reservoir, wheels from a lawn mower,etc. I don't use a lot of air. Occasionally I use a brad nailer, blow chips out a tapped hole and air up tires. I need a dependable compressor that I can stand to be in the same room with. I'd like to know what brands you guys have and would buy again. I'd like to have a quiet compressor,110 V and have 125 PSI min. Anything is an improvement over what I have.
Re: Shop compressor advice needed.
>For your needs, get whatever's least expensive at the borg. Individual differences are irrelevant.
Clint
>Sounds like you want an oil-lubed deal, but not sure you're talking portable, except for the 110v spec. Friend has a oil-lude Dewalt/Emglo with 4 gal. and "fairly" quiet. That is when compared with my Thomas oil-free. Recovery time is about 15 sec. (Thomas in 9). Pushes a bit over 4CFM and works on 110 [mol], but you might trip a 15amp circuit. Sounds like that's about what you're looking for. Good for guns, tires, etc., but wouldn't try to spray finish with it; too much pulse and not enough push.
mm
>Good Afternoon Virgil,
I had a Sears oiless compressor, about 25 gallon tank, which went up to around 100-125 psi. It lasted 10 years and then the pump blew up, and Sears couldn't support the parts.. While it lasted, I was reasonably satisfied with it to do what you have stated as a need. However, dealing with Sears for service was an ongoing nightmare as well as costly. I now have a HD/Husky with a tiny tank, maybe 2 1/2 ga. Its quieter, but takes forever to charge itself, and must then cycle a couple more times just to fill up one tire. The little Husky is great for shooting brads and pins. No good for blowing anything out. Had I to do it over again, I'd get another with about 25-30 ga tank. I would not recommend Sears. Models are available from deVilblis, Campbell Hausfeld, Quincy, and others. I notice in my area, many are being sold thru Craig's List.
George
Virgil Johnson
>Hi George.
Stopped by Sears today and checked out their compressors. Kept the Sears card in my pocket though. Something told me they would change models about the time something broke. (like my garage door opener)
Wise Choice
Jim Dillon
>Virgil,
I've had luck with my old Emglo hot-dog compressor. I built a cart to help move it. I think Dewalt bought Emglo out and now you can get them as the Dewalt/Emglo brand - only yellow not blue. If I remember right, FWW had a review in the past several years of small compressors (oiled and oil-free). I think the Thomas brand, though much more expensive, was a better performer. I use the compressor so much that I would get another the next day if mine conked out. And I have done limited spraying with a HVLP conversion gun. Oh yes, if you get one that needs oil, don't forget to change the oil fairly frequently. DAMHIKT. Good luck.
Jim
PS
>Ans use synthetic compressor oil. It prevents carbonizing of the valves, and moving parts in the pump. Ingersol-Rand's oil is marketed under the "Select" brand. It will double some manufacturer's warrantees.
mm
George (Oxford, NC)
>I can't recall the number, but I have had the Harbor Freight 21 gallon upright model that goes on sale for about $129-$149 for about three years. Like you, it is used for occassional brad nailing, blowing chips, etc. It has given me no problems and you can buy the one year extended warranty for about $12-$15.
George
Joseph Mulherin
>Virgil, type in your Search engine Harbor Freight, bookmark the page, and type in air compressors in their search window. Up will come many compressors you can buy and use at reasonable prices. I bought a pancake compressor 2yrs ago and it has work fine for me every time I needed it.
Would you consider used??
Joe Burke
>This may be a lame suggestion, and it has nothing to do with brand, but if you'd consider used, check your local Craig's List. I don't mean to be a shill for them, but I'm looking a used 2 stage and I check my local for one almost daily. In my area compressors must be plentiful because there's always a few to be had in a wide range of brands and prices. There's always some trim carpenter liquidating.
Of course, who knows in your area. But for the use you describe, and because I'm poor AND cheap, I'd have to at least look.
Thanks for the tip!
Jim Dillon
Jennifer@Indy.USA
>Virgil,
I've been real happy with my Porter Cable (made by DeVilbis, I think?) that I bought from Lowes about 5 years ago. I don't remember paying what Amazon is asking for it now? I think I paid right around $300 if this thrifty shopper remembers correctly.
Jen
Would I consider used??
Virgil Johnson
>Joe, Used is on the radar. The Craigslist here is pretty slow in the tool market.
Good news/bad news
Virgil Johnson
>The good news is that I found the problem. The bad news is that I'm cheap enough to fix this one and be stuck with it for a few more years.I took the head off the old compressor unit and found the head gasket had deteriorated and a section was stuck in the intake valve holding it open slightly. This gasket failed a few years back and I cut new one out of fiber gasket stock. I'll try cutting one from .015/.02 copper this time. I expected to see a ridge worn in the cylinder and slop in the piston but this thing has virtually no wear after 40 yrs.
Virgil Johnson
>Hello Jennifer,
How loud is this unit?
Virgil Johnson
>Jim, I've read positive reviews of the Emglo compressors and this style would tuck underneath my jointer. The Dewalt name in front of the Emglo makes me cringe as I bought a Dewalt sander and it was not what I expected. I'm considering this one if I can't get/make a gasket for the old compressor.
Good for another 40 yrs. Good luck
VLParisian
Geeze, I Wish I Was Good For That Long
