dog bit furniture
dog bit furniture
dog bit furniture
eliot d
>I have a really special cocktail table that is jet black with a million coats of polyurathane on it, so it has a very thick glass-like glossfinish. My new Olde English Bulldoge puppy managed to chew up one of the corners. My wife is ready to kill me and the dog! I sanded the scratches out starting with 600 grit wet/dry and going all the way up to 4000 Micromesh; and I stained it with Fiebings Marine black shoe polish, which is basically a black dye. And the color is right. Now it looks smooth, but I have to try to get the gloss back. I suppose I should try painting on clear poly. What do you suggest?
Re: dog bit furniture
Patching polyurethane
>Sorry about the damage, Eliot. If you were able to *start* with 600 grit, they must have been really light scratches. If my dog munched on that table, you'd be starting with 60 grit. :-)
I'm no expert on patching polyurethane; in fact, I've never been really successful at it. It seems that when you go to sand between coats, you create "witness lines" that look a bit like lines on a contour map, where the new coat meets the earlier one. That said, the idea is to build the right amount of film thickness in the repaired area, feather it into the existing finish, and then spray the whole piece again, so you have a continuous topcoat to cover any witness lines. Use gloss product all the way, and rub it out to whatever sheen you want when you're all through.
Re: Out The Dog House
>Eliot,
If the color matches, I'd try a little spray lacquer which you then rub out to blend the gloss You may have to blacken and apply a pore filler first to get an even gloss to match the rest, but it will be easier than trying to fuss with an oil finish. The prior poly was a "clear" coating rather than pigmented, right?
mm
But
>As Ellis said, you may still get a witness line. If so, your option, like He said, is to redo the whole top in a single coat.
mm
eliot d
>I have a small piece of the finish that came off in my hand. It looks to be about the thickness of a contact lens --really quite thick. It is black, so I think the poly must have been pigmented. I have the feeling that I should try to mix up some sort of slurry that I could brush on and then sand and buff it. But this just isn't my thing. I could use any specific help you all can give me..
Suggestion
>Stop. Break that chip in half and put it in a bit of lacquer thinner. If it dissovles, you finishs is black lacquer, not poly, and will be simplicity itself to repair. I know that pigmented poly is around, but I doubt that its common use on furniture.
Call us back. |;-}}
another possibility
Michael Dresdner
>Do the lacquer thinner test on the chip, but from your description of the finish I would bet it is neither lacquer nor polyurethane, but rather polyester, the most common of the very thick, high gloss commercial finishes. The other possibility is that it is two part urethane, the finish normally sprayed on cars.
These finishes can not be redissolved, so your repair strategy with have to follow what Ellis suggested; build up the finish in the void, sand flush with the surrounding area, sand the entire affected surface and recoat the entire thing. If you want to retain the same durability you will need another curing finish. I doubt you want to mess with two or three part coatings (automotive urethane is two part; polyester is typically three part) but oil based polyurethane will go over whatever is on there, provided you clean, degrease and sand the surface first, and will give you very good durability.
As for adding color, it is fairly easy to add color to any coating. All you need do is identify the solvent in it and use a dye or pigment compatible with that solvent. Dyes come in solvencies compatible to just about everything. In this case, the easy way, since you already have colored the wood black and only need a tiny bit in the clear coats, is to use a universal black tint, such as Mixol.
Re: another possibility
eliot d
>Thanks for all the suggestions. I will try the lacquer thinner test, and if that doesn't work, I'll go with the polyester and Mixol. I'll try to remember to post back to say how it worked. Thanks again.
eliot d
>Yes but here's the problem: This is a message form Larry Stock, hotshot at one of the polyethylene suppliers.
"Your still in big trouble!
There is no solvent for polyethylene.
You can use finer 600 grit sand paper and maybe try a propane torch to add
some gloss by just melting the surface. Be careful not to burn the surface.
Just wisp the flame over to gloss up the surface."
Larry Stock
On 1/13/08 12:28 PM, "Claudia Feldman" wrote:
> Hi, I'm in big trouble and am in the dog house! We just bought an expensive
> artsy cocktail table( goes by the name Bella Bella), and my new puppy chewed
> on the corners, putting tooth marks all around two of them. I was told that
> the finish is probably polyethylene. I happen to be a wood worker. But I am
> no furniture restorer. I can certainly sand out the scratches and have done
> so on one corner using grits all the way up to 400 Micromesh. So it's smooth
> now. The color is jet black. But I have no idea how to get the gloss back. I
> would like to paint a small amount of polyethylene on and mix in some black
> Mixol with the proper solvent to match the jet black color. Can you help me
> out?
>elliot,
Sounds like either you're going to be refinishing the entire top or sleeping with the pooch under the stars!
eliot d
>You've got that about right! I don't like to give up, though; and I still think there are some solvents that will work at high temperatures. (But I'm not sure and don't know what they are.) If all else fails, I may just sand to get it smooth as possible, stain with black Fiebigs shoe polish, and take my time suing a tampon and a French polish.
