A55 Smoothing Plane
Floor model drill press recommendation
Terry Alexander
>Fellow woodworkers,
I have survived for many years with my trusty Delta benchtop drill press. I am rather confident that I am going to come into some disposable income and am thinking about upgrading to a floor model drill press.
I would really appreciate some recommendations.
As always......TIA
Terry Alexander
Re: Floor model drill press recommendation
Bart Goldberg
Bart Goldberg
>I'd take a look at the new Powermatic PM2800. Its set up specifically for woodworking. Note that I've only seen ads for this and can't comment on how well its built, but Powermatic usually makes excellent products.
Bart
Jay St. Peter - Southern, MD
>I keep thinking about upgrading my DP since it is getting worn and has a good amount of runout these days. My choice right now would be the Steel City. It has around 6" of spindle travel and a good speed range. I'd rather have variable speed, but most of the other newer "woodworkers" drill presses come with a low speed that is too fast IMO. I can't really imagine running a fly cutter or 2.5" forstner at 5-800 RPM. My second choice is between the older Delta VS DP or the Grizzly 20" for more capacity. Both have spindle travel over what I consider my minimum acceptable of 4.5".
Jay
Re: Floor model drill press recommendation *LINK*
Ron Hildreth
>Terry,
You're going to get many different opinions on drill presses, about like table saws, jointers, or any other shop equipment. You gotta ask yourself what do you think you might be using it for in the future? I gave it a lot of thought before I bought, and could see myself building or repairing things like chairs or bar stools (especially the ones I've been known to fall off of!). That's why I decided to buy the Grizzly radial drill press, pictured in the link below. Glad I did, cause not three days after getting it, my SIL wanted a childs rocking chair rebuilt, and needed the capability of drilling unusual angles that I wouldn't have been able to do without building some sort of jig. You'll notice the price isn't bad, although it has increased since I bought mine four years ago at $179.00, plus shipping.
Ron in Iowa
Grizzly's Radial Drill Press
Ron Hildreth
>This is what I've done to my radial drill press to make it even more utilitarian!
Ron in Iowa
Bob Lemon Sacramento Ca.
>Bart, if you have the money to buy a big Powermatic VS you might consider a mill/drill machine. Having a good mill/drill machine will open up a whole new world for you.
Mill/drill machine
Cody Lewis in LV
>Bob, I'm assuming a mill/drill machine has a bunch more capabilities than a simple drill press, but I'm not familiar with what a mill/drill is. Would you mind helping out the rookies with a quick description of what you mean by "open up a whole new world" of possibilities?
Bart Goldberg
Yes, Please Explain about World Of Possibilites
Bart Goldberg
Re: I purchased the Powermatic PM2800
Larry Clinton At Frankfort (Central)., Indiana
>My old 40's - 50's Delta benchtop had some problems with the chuck and I decided it was time to spring for a new floor model press. I looked at all the units (Steel City, Delta, Powermatic, Jet etc.) on the web and really liked the features of the PM2800. At the time it was on a special for $899 with free shipping and a $50 gift card. The press has a 1 hp motor, reeves drive variable speed from 400 to 3000 RPM, a laser pointer system, Led lighting on the table. The table has 2 extensions, and an excellent tilt mechanism, as well as a geared lift. The 5/8 chuck is keyless. The variable speed works very well and has a 4 place digital readout. The reeves drive is a little noisy but the press works very well. It also includes a pretty good fence with a dust collector hookup. I just looked and the press is on a special for $849 (not sure about the shipping though). I would buy the same unit again.
ScottS
>As I understand it, a mill/drill is sort of a combination of a drill press and a metal milling machine (e.g. Bridgeport mill). I think the biggest difference between a mill/drill and a drill press is that the mill/drill has a reasonably large X-Y table. On a traditional mill, the table can be precisely positioned in .001" increments. Presumably, a mill/drill would accept end mills or other cutters typically used in a milling machine. These cutters, when combined with the precise movements of the table, would allow you to make accurate grooves, pockets, and other shapes in wood or metal. Of course, you can also use the movement of the table to accurately position holes without needing a special jig.
