hold down
Gill Turpin
>To
Willian Duffield- the shop made hold downs is one of the best designs I have seen and consequently made and used.
Thanks for your bright idea.
cheers
gill
hold down
Gill Turpin
>To
cheers
gill
Re: hold down
William Duffield
>The original idea isn't mine. I just made it a bit easier to understand, after I had refined and tested the concept in my shop.
Another related tip: If you have t-track (manufactured by Incra and others) mounted in your bench, table, jig, fixture or fence, you can easily swap out the threaded rod in the hold downs described in my article with a t-bolt for even more versatility. You can even buy attachments made by Rousseau (reference model 3501 for hex head bolt adaptor) that you can use to install them in your miter slot or miter track.
And one more, much older idea: If you have a hardwood bench top at least 2" thick, the old fashioned holdfasts work even better, because they are so much quicker to set and release. Note that you can only use these where you have a 3/4" diameter hole drilled through your bench top or bench leg and a mallet close at hand. Ductile iron holdfasts (Avoid the Chinese cast iron ones!) are available from Woodcraft and others. Very elegant hand made wrought iron holdfasts are sometimes available from Phil Koontz and Jake the Russian at the Galena Village Blacksmith. Joel at Tools for Working Wood has developed a Gramercy Tools forged steel holdfast that gets good reviews.
Sir William of the Cohansey
