Sharpening Scissors??
Marv
>Over the years I have sharpened the household scissors. A friend of mine is looking for a treatise or step by step instructions. I've done a little googling but didn't find anything of significance. Is anyone aware of some detailed info on the subject?
Thank you,
Marv
PS...please don't suggest cutting sandpaper to sharpen them. That makes me cringe.
Re: Sharpening Scissors??
Re: Try Leonard Lee's book
>on sharpening - "The Complete Guide to Sharpening" it may have something in there.
Of course if your friend has a Tormek, he can get a scissors jig and use that :).
Carol - now in NC Nebraska
>I use a fine diamond file/stick/card. Open the scissors all the way and clamp one side in a vise. Make sure the loose side will not get in your way or hurt you in some way. Lay the diamond file flat of the angled edge and draw across it 3-4 times.
To draw means (to me!) to hold the file with both hands and pull or push across the edge, maintaining the same angle as the edges. I do not go back and forth. Just 3-4 times in one direction only.
Do the same to the other side. Do not file on the flat of the scissors.
This is how we did it when I worked for the telephone company and we cut cables with those scissors. There we just had a mill file. That leaves things a little coarse for ordinary scissors. The diamond file leaves a smooth edge and thus a smooth cutting scissors.
Doug Reynolds in Seattle
>I did a bunch including very small hair scissors on the Tormek as Carol suggested with good luck.
Tony - Memphis
>Yeah, the Tormek jig works great. Made all my beat up old scissors just like new. Very easy too.
Tony
Carol, please clarify....
Tim Greif - West of Chicago
>When you say lay it on the angled edge and draw it across..., are you drawing it pretty much perpendicular to the length of the blade from the cutting edge to the non-cutting edge like when you sharpen a knife? Or are you drawing it the length of the scissor blade?
Re: Carol, please clarify....
Bill Howatt
>I did mine the length of the blades. Seems to me if you do a bunch of perpendicular cuts you would be more likely to get "steps" in the blade.
Carol, thanks for the tip, the scissors never worked better.
Bill
Sonja Lemon Sacramento Ca.
>Marv, Another alternative to the Tormek or file is to purchase a small sissor sharpener from the fabric store. It is made by Fiskar and is small enough to carry in your pocket. Just draw the sissors through the slot a few times and it is sharpened.
It's imporant
Lee Schierer - McKean, PA
>It is important that when you draw the file across the blade in a perpendicular direction that you pull toward the outside edge of the blade so as to not create any burrs on the inside edges where the cutting occurs.
Most scissors are too hard for a file, but regular ceramic stones will also sharpen them.
Lee
>I begin at the 'hinge' of the scissors and draw it out to the tip. And if your scissor halves separate, it is even easier, but I still would begin from the inner most end and go to the tip.
You are working on the face of the thickness of the blade, if that is what you are asking. Usually that edge is slightly angled from the face of the blade.
Re: It's imporant
>Thanks, Lee.
You are right. I forgot about drawing from the inside edge to the tip of the blade.
I also take the diamond file and place it flat on the inside face and draw once off the cutting edge to remove any possibility of a burr. Obviously this is with the scissors out of the vise and with the flat FLAT on the face. No rounding off here!
Marv
>Thanks everybody for your suggestion....
Marv
