OT: Attaching 2x4's to poured concrete
Dan Mitchell
>I posted a couple days back about the value of a used hot tub (as I suspected, turns out, "not much" ;-) We live on a wooded 1 acre lot, and the tub was located in an attached sun room. One reason I wanted to rip out the tub, in addition to our not using it, is rats were nesting beneath and around the tub & the steps up to it. Now that I have the tub out, I can see why it was so easy for them to get inside. The walls of the sun room are basically framed vertical wooden siding. As the pic shows, the trouble is the numskulls who erected the structure left large gaps between slab & these vertical boards. The picture is from the inside, on the other side of this wall there is either a deck or just the great outdoors. I'm thinking I'll run 2x4's, 2 high in spots requiring it, flat along the concrete to fill this gap. I'm wondering the best/easiest way (generally an oxymoron, I know... ;-) to attach the 2x4's to the concrete slab. The 4x4 uprights are attached to the slab with brackets, making it difficult to toe nail any such studs to them. I've seen those .22 load nail guns, which seem pretty quick & dirty, though I've never used one. Would one work well for this application? Helpful ideas appreciated!
TIA
Dan
