3 phase 5hp motor to regular 220???
lee beeden
>I may have won the bid on a 5hp 3 phase unisaw on e-bay.I'm wondering what my options are for using this saw on a regular 220 circuit. I may have made a mistake bidding on this saw!!
Lee
lee beeden
Lee
Re: 3 phase 5hp motor to regular 220???
Thomas S Stockton
>A phase converter will do the trick or it would probably be cheaper to change out the motor. The unisaw has a wierd mount but I saw a adapter plate someone sells just can't remember where.
Tom
>Find someone who knows how to what to buy and how to hook up a Variable Frequency Drive. I think for less than $300 you can probably get one.
Your other options are to buy a Rotary Phase converter or to add a 3rd phase with a seperate motor.
Gary Evans Tallassee, TN
>Hi Lee,
I agree with John on the VFD. I use one on my 3 HP DeWalt 14" RAS. It cost me $150 off Ebay. I'm not sure variable speed is a necessity for a table saw or a radial arm saw, which is one of the big draws to use one on a lathe or bandsaw, but it sure is nice to fire up that big motor at 60 cycles and listen to it hum.
Do a little research on the available auctions on e-bay. Most give links to manufacturer's websites for more info. Be sure and check retail pricing, also. There are some good deals available for good equipment. I'd be surprised if it cost you much more than $200 for a serviceable drive. A lot of times, it's just last year's model, at a discount. Still works for me. I don't have to have the latest technology, I just need something that does the job, and that is to spin a 3 PH motor with 1 PH 220V power.
There is a lot of info available on the web regarding Variable Frequency Drives. Google is also a good place to seek info.
Gary
Dick Coers------WebKitFormBoundaryqFOmq51H3saAc+aC
>Here's a site that shows how to make an adapter for a standard frame motor.
http://www.owwm.com/FAQ/UnisawMotors.asp
Mike Fitterling
>A rotary phase converter is not hard to build and not terribly expensive. A nice thing about having one, too, is that is available to run other three phase motors that may come along in form of great deals on old arn. I built mine for a couple hundred and it services my Northfield jointer and will soon service an old Dewalt GP RAS. The RPC will yield full HP where a static converter will yield less hp. Not sure how the HP is affected with a VFD; I am not familiar with them. IIRC VFDs are often used to control RPM on machinery, like lathes.
Cheers,
Mike
heres the adapter plate
Thomas S Stockton
Contact him. Has 1 FS *LINK*
Sawdust Everywhere!
>Don't know if he has sold the motor yet.
See this thread.
http://www.forums.woodnet.net/ubbthreads/showflat.php?Cat=&Number=3444887&page=0&view=collapsed&sb=5&o=
It's a direct swap if you don't mind the 3hp instead of the 5hp. I have the 3hp and it is plenty unless you're running a caninet shop
Thread
There are some advangages for a FVD.
Forrest Addy
>There are some advangages for a FVD.. If you don't already know, a variable frequency drive (VFD) is a box of industrial rated electronics that converted line AC into variable frequency three phase AC. There are control circuit on board that monitor motor current and other operating parameters such that a motor's overload and thremal ratings are never exceeded.
You can connect it a variety of ways including through the machine's existing controls. Installing a VFD can be quite a technical challenge but the manuals that come with the unit are simply written. If you can follow enumerated steps you can make a successful installation.
It might seem like overkill to install a VFD on a table saw. Motor overlaod protection is but one of the advantages. Others are variable speed (if you ever install a sanding disk, a slower blade speed is a real advantage), controlled accel (no more start with a bang; popping breakers), controlled decel (sometimes called "electronc brakes" the motor comes to a stop over a set time - 3 seconds works well - so no more two minute coasts). It's also quiet, efficient, and compact and not that expensive if you shop wisely.
helps if the link is there *LINK*
Thomas S Stockton
motor plate
Agree, with one caveat
Rick Christopherson
>I've been watching this thread for a couple of days but did not post until now. I agree that a VFD is one of the best ways to go with doing phase conversion these days due to their low cost and the other benefits that Forrest mentioned, however, once you get into the 5 hp motor size, the cost does go up substantially.
In order to run a 5 hp motor on a VFD you will need to oversize the VFD to account for the fact that these larger models are not designed to run from single-phase power. They will still perform the task properly from a single-phase supply, but they need to be "derated" to handle the larger input current.
The reason for my posting is that you understand that even though the VFD is not rated for single-phase input, it will still run from your 240 volt, single-phase power, but for a 5 hp motor, you will need a 7 hp VFD. The cost is higher, but it is worth it for the performance. Given the choice between a Rotary phase converter and a VFD for the same amount of money, I would choose the VFD.
Re: There are some advangages for a FVD.
Denis Ch�nard, Orl�ans, Ont.
>Saw those demonstrated once, and man, these are so cool... But the expense kept me from getting one for my hobbyist shop, between the VFD and the 3 phase motor... I'd love to get one for my lathe, among other uses... Some day...
DC
Charlie M
>A static phase converter for 5hp should run around $175 - $250 depending on the source.
