An easy way to apply shellac
Bill Tindall, E.TN
>When I started using shellac I looked for recommendations on how to apply it. Various expensive brushes were recommended. After spending a lot of money on brushes I concluded that if this was the only way to apply shellac I was not going to be successful using it.
It does spray successfully, but it is more difficult to spray than lacquer.
Then I was shown the ease at which it can be applied with a wad of wool wrapped in a cotton or linen cloth.
I was doing the insides of some boxes today and there on my bench was a foam brush I had used to apply some "synthetic" milk paint ( have I ever said how much I hate real milk paint or that I am cheap. I had washed out the 5 cent foam brush for reuse). I tried it for the shellac, a one pound dilution for box and drawer insides.
This foam brush worked very nicely. It held a bunch of shellac, the key to successful application. And it applied it smoothly and evenly. While I have not used it enough to decide that it is better than a wad of wool, it is certainly worth further evaluation.
Re: An easy way to apply shellac
Don Orr
>That's great to hear Bill. I have been hesitant to try it since the cheapo foam brushes I have say "not for shellac or lacquer" right on the handle. I have not bothered to see what happens to the foam if used with those products and now I don't have to. Everybody knows I'm cheap but did you know I'm lazy too ?? ;o))
Craig in SIlverdale
>I usually use cheesecloth. For the seal coats anyway. I love shellac.
Re: Spray?
>Hi Bill,
I've always found shellac rather easy to spray and actually have an easier time than lacquer because it was easier to control and more forgiving IMHO so long as I don't try to push the finish.. I've done some shellac finishes that were pretty much done "off-the-gun."
You should take care with the foam brushes because the glue some of them use to hold those plastic stiffener blades in the foam is subject to attack by alcohol. Lacquer thinner components can dissolve the whole thing! |;-{{. Don't think you want your brush falling apart in the middle of a stroke. You can prevent the "disassembly by alcohol" by putting a heavy duty staple in that goes through that stiffener to lock the foam on the tang.
What problems do you have spraying shellac?
My easier way to apply shellac
Dave Bair, Eaton Rapids, MI
>I use a white foam mini roller to apply a good heavy coat and then tip it off with a nylon brush before it starts to dry. The brush is dipped in alcohol and shaken just before use. I can get quite a large panel (60"x30") coated without the problems I used to have using a brush alone.
problems I have with spraying shellac
Bill Tindall, E.TN
>Lacquer is formulated to be sprayed. It is dissolved in a solvent system that evaporates in a controlled manner such that sagging is lessened as well as blushing. The film former in lacquer is a polymer and its properties are such that the viscosity of the solution is a third or forth power of concentration. Some fast evaporating solvent is in the formulation and when this solvent flashes off the viscosity of the wet film rockets up and lessens sagging, yet the film is still wet enough to flow and level. And the slower evaporating solvents retard blushing.
The first time I sprayed shellac I condensed so much water on the piece that it had a continuous film of water deposited on it. Never saw that with lacquer.
That said, shellac can certainly be sprayed and done so in semi-closed environment that I would never risk with lacquer. On the other hand, for the inside of a drawer the wool pad or foam brush are very handy and none of the expensive shellac is wasted to overspray.
Tell me more.....
Bill Tindall, E.TN
>What nap length do you use on the roller and what pound cut of shellac?
Re: Blushing Sags
>I had a shellac blush problem just once; when I tried to spray shellac on a 90* day with humidity at about 99% right after a rain storm. I guess I got what I asked for, eh? |;-}}}}
One thing I learned early was not to push the material. Shellac has the marvelous attribute of 100% burn-in with the prior layer, so applying many light coats that never get heavy enough to sag gets me to the final film thickness and gloss I want with off-the-gun results. Rush and push it too heavy, and, sure, you'll get runs. True, lacquer's a much more complex chemical system, but I don't try to apply shellac the same way. What mix were you using when your shellac sagged or ran?
I've shot both shellac and lacquer inside drawers (corners can be tricky) by HVLP, but had to dial the air even lower to control the bounce. Overspray wasn't a big problem, but padding or brushing does completely eliminate it.
BTW, I've had the best results inside drawers using waterborne sanding sealer; goes on with that foam brush and levels out beautifully. Try one, you'll like it. I use General's.
mm
Re: Tell me more.....
>The roller is foam, so there's no nap. The foam color is white, if that makes a difference. Some rollers warn about using with shellac. I use both Seal Coat and Bullseye right out of the can.
