propolis, and feeding the bees
JohnKJordan in East TN
>Gary,
My bees forage in lots of things. (I have five hives.) I've seen them a lot on the brocoli and cabbage plants in the garden the last few warm days. I have also seen them around the door to my shop on wood chips and pieces.
I wonder if they are after resins in the wood? Bees collect propolis as well as for pollen and nectar. Propolis is substanced containing resin they collect from a variety of plant sources - bees use it to seal up gaps in the hive, cover unwanted things they can't get rid of (such as a mouse carcass), and generally glue things (such as hive boxes) together. Beekeepers spend a considerable effort prying apart and scraping frames glued together by propolis. Violin makers love propolis for finishes - a local luthier asked me to save propolis for him, the darker the better. Propolis also is reported to have healing effects for humans.
Hey, if you want to feed the bees, cola is not recommended (unless you want to feed the yellowjackets in the summer!) Use corn syrup, honey, or dissolve plain table sugar in water. The normal ratio is about 5 lbs of sugar to 1 gallon of water, but just dissolving as much as will go into warm water will work fine (about like you'd do for a hummingbird feeder.) Keeping them from drowning is the biggest problem. Your piece of wood in the tray works well for giving them plain water, but may not work so well for a thicker syrup or honey - if they fall in the water they can get out, but they'll get stuck and drown in something thicker. I occasionally pour unwanted honey out on rocks or large plant leaves, but honey is pretty thick. A little sugar water a shallow plate with slighly curved sides would work well. We feed sugar water to the bees directly in the hive, but use a special plastic tray on the top which is constructed to prevent drowning.
Also, the bees love to get out on warm winter days, but they really shouldn't need suplimentary feed unless the hive is desperate, in which case a little extra food outside probably won't really help - they may need gallons of syrup placed right in the hive where they can get to it when the weather is cold. Beekeepers who don't leave enough honey in the hive to last them through the winter either feed them or they die.
