slot mortiser ?
slot mortiser ?
slot mortiser ?
Todd
>Other than Laguna, can anyone offer up manufacturers of slot mortisers or a machine that will due the same?
Re: slot mortiser ?
Re: slot mortiser ?
Paul Cates - Henderson, KY
>Hi Todd,
Off the top of my head, mfrs. of slot mortisers include: Grizzly, Rojek, and Laguna plus the industrial mfrs. Search the archives here - there has been a bit of discussion about them in the past. If you have access, see articles in American Woodworker (March 2004), FWW (#142?) and Bill Hylton's book "Router Magic" about making your own.
Also, check out these writeups in the articles section:
Mortise-Flex:
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=newarticles&file=articles_110.shtml
Grizzly review:
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=reviews&file=articles_729.shtml
Make your own with a router:
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=powertools&file=articles_834.shtml
Re: slot mortiser ?
Rick L
Re: Plenty of slot mortisers out there...
Rick L
>The Laguna Platinum is the most affordable at around $1,000 in it's category of slot mortisers. The Grizzly G0540 is an alternative low budget choice. The Rojek is around $1,600. The slot mortiser goes back to the 50's and is being made by SCMI, Sicar, Griggio, Paolini, Invicta and many others but expect to pay several thousand for the higher end machines. In 30 years I have only seen six used slot mortisers so don't expect to find a deal out there.
Re: slot mortiser ?
Buy a multi router if you can afford it.
Ed Snow
>It may be middle of the road expensive but it is the most versatile and best slot mortising tool I have used. I have used about all of them various places and the multi router is what I will be putting in my shop when I finally strike out.
Re: slot mortiser ?
Ed, how is your Grizzly G0540 working?
Craig H
>Ed,
I read your review of the Grizzly G0540 and was considering the same thing. Any tips or changes you'd recommend? Is there a particular end mill that has worked well?
Thank
Craig
Re: slot mortiser ?
Re: Buy a multi router if you can afford it.
Howard
>I agree, it's a great machine. The first time I did dovetails they came out perfect.
Howard
Re: slot mortiser ?
Re: Ed, how is your Grizzly G0540 working?
Ed Snow
>The grizzly still works just fine for most things. I have run into some capacity issues recently, but nothing you would ever have issues with in normal furniture or even odder things. I have been using the multi router exclusively in a shop for almost two years, it is much much more versatile and has much better capacity and features, it is also easier to set up.
My father uses the grizzly all the time now. I use two flute endmills designed for aluminum and have adopted the laguna suggested method or repeated plunging and then zipping across the mortise to kill the webs and humps, it is a very fast process.
Re: slot mortiser ?
Thanks for your response!
Craig H
