The Opposite of the Saw Stop *LINK*
Ray DuBose - Memphis TN
>I think I would find a Different way to resaw Boards and attempt to keep all my fingers. This guy is a Luthier, I think I'll stick with furniture.
Ray
New Table Saw
Re: The Opposite of the Saw Stop *LINK*
That's a very bad video!
Eddie Pacheco; San Jose, Ca.
>If only .01% of the viewers, to date, were to try that and get hurt that would be 8 people too many.
YIKES!!!!!!!!!!!!!
Dan Mitchell
Bill Howatt
>Apart from the unused portion of the blade being exposed is it really a lot different than using a regular TS with the blade at maximum exposure without a guard?
Bill
Marv
>If the guy is going to resaw in that manner, the least he should do is cut what he needs from a longer board so his hands stay far away from the blade and not cut the full length. Gives me the Willy,s to watch that.
Eric in Los Gatos
>I had to go back and see it again to do a finger count. It actually looks like he's got all 10 so it must be safe. NOT!!!
Reminds me of drivers ed movies.
Eric in Los Gatos
Paul Woolson
>That might just qualify as the dumbest thing I've ever seen. Aside from the obvious stupidity of the blade being totally exposed, the weight of the cut-off board will close around the back of the blade and cause the inevitable kickback from h#$$.
Gives luthiers a bad name.
Re: Looks like he has done it a number of times
Wayne
Howard Norman
>Well that is something I wouldn't do but I would guess that he has done it more than once.
Howard
Rob Sandow
>Yes it is. The offcut is essentially resting on the top of the blade, ready to catch and be spun back at high speed at any time. Also consider the fact that the table, in this case most likely a shaper and not a table saw, has no possibility of installing a splitter to keep the offcut separate from the blade. Yikes. It has to be that way because as the cuts are made, the blade must be able to travel up and down to accommodate the changing thickness of the blanks. You couldn't just fix a splitter to the fence. I will stick with the band saw.
Stuart Hough
>That gave me nightmares...and I'm wide awake!!!!!
Binen
>I would never do that myself or suggest that anyone else try it. Being a bit of a contrarian after watching the process several times, it doesn�t look that bad to me. Other than the fully exposed blade the process looks fairly safe.
Binen
Yikes is right!!!
Steve in Fresno, Go Dogs!!
Jason Roehl in Lafayette, IN
I agree.
>It's really not much different from a shaper operation. A push stick would certainly make it a little safer, but the bottom line is that no matter what you do with power tools, you need to keep your fingers out of the way.
I wouldn't be too worried about the kerf closing, either. He's resawing thin pieces off, so that thin top piece isn't likely to be able to bind the blade at all.
Jason
heightened awareness
JohnKJordan in East TN
>I don't read the language (Portuguese?), but the About this Video text seems to say something like "submitted by a professional, not recommended [except for]? the adventurous". Can anyone translate properly?
It does look scary, but I'm sure many of us would be horrified at some of the methods of work used daily in the world outside our OSHA-patterned workshops. And there is the debate that doing something scary may instill constant, heightened awareness, while using an idiot-proof method, i.e., SawStop, might actually give a false sense of security and promote a ho-hum attitude about safety. The recent discussion here about the wisdom of using the SawStop in schools made me think of a possible solution: install the SawStop saws in secret and don't tell the users - keep them on their toes!
This Old House
Jerry Nicholson
>Kind of reminds me of a recent episode of TOH. Keven was extolling the virtues of The Old Cabinet Maker who was then shown trimming a board freehand on his guardless and splitterless table saw and making a fairly risky cut on his miter saw. Kevin didn't say anything about the guy's missing left thumb though.
Jerry
Re: heightened awareness
>From Babelfish:
"Manuscript effected by a professional, not recommended for adventurers!"
My Portuguese is too old, rusty and decrepit to translate something like that, plus I was only minimally fluent when I was speaking it some 18 years ago (I lived in Salvador, Brazil for a year).
You make a good point about complacency, though, John. While I am not afraid, per se, of using a table saw, every time I turn one on, my adrenaline kicks it up a notch, so I do have the heightened awareness of which you speak. That's true on my part for most of the more dangerous power tools I tend to use or when I'm going up and down a fully-extended 40-foot ladder.
Jason
Re: This Old House
Dave Bair, Eaton Rapids, MI
>Even worse, that was Norm, not Kevin.
Al I have to say is
Dominic Greco in Richboro PA
HOLY CRAP that is scary looking!!!
I wouldn't work with that rig for a whole pile of LN Chisels.
Well,....maybe just for a couple minutes. I mean, they're LN chisels for gosh sakes! :>)
>Use of a Saw-Stop would actually lead to extreme saftey practices because if you trip the saw-stop, you have to replace the cartridge and the blade. And that costs money, and if they are anything like the guys here, you'll do anything to save money on tools.
Horizontal Re-saw
Ray Carson, Lawrenceville, NJ
>No thank you. That is a accident waiting to happen. It made my blood run cold.
Ray
Marv
>As a young man, actually starting when I was 13 I worked in my Fathers small stud mill in Oregon, early 1950,s. What you see in the video is nothing compared to how unsafe those sawmills were in those days. Huge circular saw blades only inches from hands and drive belts totally uncovered right next to you. Talk about kick-backs! Safety wasn't an issue. The only issue was producing maximum BF of lumber each day.
In a small sawmill that was powered by a huge diesel engine, everyone was subjected to breathing the fumes all day. All the slabs and sawdust was being burnt nearby. The wind would blow the smoke to the work areas. In the summer, dust from moving the logs around the mill was in the air and of course sawdust was everywhere. OSHA? Never heard of it until the early 1970,s. I'm sure alot of you old timers can indentify with what I'm talking about here regarding sawmills in those days.
Marv
Re: Saw pics of something similar
Brian in Brighton
>In a Wood mag (?) several years ago was an article about a guy in Mexico who makes wood crap fro sale to tourists from their local ironwood. He had an arbor shaft and a saw blade and 'freehanded' it for making the carvings on the open saw blade as if it was a belt sander. Scary to see in real life.
Brian in Brighton.
Some of these people might be proof that natural selection does cover every idiot. :-)
Lee Gordon
Re: This Old House
Lee Gordon
>As long as the guy was wearing these -- tap, tap -- safety glasses.
Rough translation on YOU TUBE
>Under: About this video - (on YOU TUBE)
Violamineira, I show like the wood is serrated for become Country Viola. Access www.violamineira.blogspot.com...viola country wood luthier bookmatch NOTICE: Handling performed by a professional, done not recommend for adventurers!
Ray
