OT: any market for a used hot tub?
Dan Mitchell
>My wife & I recently moved into a house in the Seattle area that has a large hot tub in a sun porch area. We probably wouldn't use this thing more than a few times a year, even if we DID have the $$$ to keep it at 90 whatever degrees 24/7, so I'm planning to remove it. I'm wondering though if there's any market for a used hot tub. It's a big thing, about 6' square. Looks like a reasonably decent example in terms of quality. From paperwork we got with the house, I'd say it's early '90's vintage. One main problem, it looks like the sun porch was built around the thing, there is a wall on one side containing a door which might be removable if selling it was worthwhile. Otherwise, I'm going to cut it into pieces with my sawzall & haul it to the dump.
Thanks for any input
Dan
Re: OT: any market for a used hot tub?
David Yoho
>Don't know if this is a good idea but what would you lose by putting it on Craig's List for your area? You never know - one man's junk is another man's treasure!
David
I see that a lot here in the SF bay area
Eddie Pacheco; San Jose, Ca.
>Today alone there are/were 3 ads for free hot tubs. Some are crappy and some are worth the time to re-install. Many times the redwood decking is listed as "free redwood, you haul"
Re: I see that a lot here in the SF bay area
Dan Mitchell
>David & Eddie - Thanks for the replies. I figured that was the case, but thought I'd get a little input here. Even selling it, I'd have to get a fairly good amount to make it worth while to remove a wall to get it the heck out of there.
Now where'd I put that sawzall ;-)
Dan
Jim DeLaney, Austintown, Ohio
>Before you cut it up, you might want to salvage the motor(s) out of it. I took two nice 3 hp, 3450 rpm motors out of my old one. They had the pumps attached to them, but those were easy to remove, too. Gave me a couple nice buffer motors.
Jim D.
Dan Mitchell
>Yup, I plan to do the same. The hot tub has already contributed to my shop. One of 2 breaker panels we have is out in the shop area, it had a 220/50 amp going to the hot tub, which I replaced with a 30 amp for the 220 line I ran to my dust collector ;-)
Dan
Ells
>Around Boulder you usually see older ones listed for a few hundred bucks, which is about what they'd be worth for salvage or if it needed to be fixed up. For top dollar you would need to get it running yourself and be able to demonstrate it functions and lack of leaks. Condition of inside of the tube is a big consideration as well as any leaks.
Ells
It MAY have a MINOR leak...
Dan Mitchell
>What do you think? ;-)
Thanks all for the replies.
Re: It MAY have a MINOR leak...
Ells
>Let's see, a sheet of plexiglas, some caulk, and you might be good to go.
Ells
Re: Waste of a good cow trough.
Brian in Brighton
