Delta 12" bandsaw and starter capacitor
Terry Alexander
>This board diagnosed that the starter capacitor on my Delta bandsaw was going out. I have to open the upper door and give the wheel a spin to get it going. Once going, it performs just fine.
I called Delta today to find out how much a starter capacitor would cost. Verdict is that that is not a serviceable part and all they can do is sell me a whole new motor. (NOT)
Having said/typed all of that, do you have any suggestions where I can purchase the starter capacitor? What should I expect to pay?
If not....what kind of shop would I take the motor to to get it serviced..and again.....ballpark....what would that cost me?
As always...TIA
Terry Alexander
Re: Delta 12" bandsaw and starter capacitor
>I would look in the Yellow Pages under Motor Repair or Electric motor Repair. Before you call, either position yourself at the motor so you can read the label to them, or write down the info. They may be able to Cross reference the motor and tell you exactly what you need. At worst you will have to take the motor to them. I don't know where you are, but I would expect to pay $10 to $20 for the capacitor and whatever the shop minimum is to install it $35 to $50. that would include some sort of minimal check up and a start and run to be sure it was good. It really is as easy as unplugging the old one and plugging in the new one (a couple of wires). Probably one screw holding the cover on. Be sure the saw is unplugged and ask them if it is important to discharge the capacitor (And how) before you change it. (Those things will BITE you.)
The advantage to taking it to the shop is that it might not be the capacitor. It could be the starter contacts. They could blow it out for you or repair the contacts, probably for a similar amount of money. OTOH, buy the capacitor and keep the receipt. If that is not the fix, they may refund your money and fix it for you On the second trip.
Ken OakleyWarming Up St. Cloud, Fla.
>If there is an air conditioning parts supply house in your area they should have all kinds of start capacitors. It is a real simple job to change one. It is usually on top of the motor held on with two small screws. On mine there is a start capacitor and a run capacitor, the bigger of the two will be the start capacitor. Most central air conditioning units use motors similar to the ones on the bandsaw.
Dave LaPine
>You might also check with Grainger
Paul Leuba
>I had a similar problem on my 12" Craftsman bandsaw and figured it was the motor capacitor. I removed the old capacitor from the motor and read its capacity on the attached label in mfd. (microfareds as I recall). In any case I use Google to search for "Capacitors" and found a supply house that had a replacement for about $7.00 each, as I recall. In any case, I purchased two new capacitors. One to use and a spare. After replacing the inoperable one with one of the new ones, the machine worked OK for about two years. Then the capacitor went up again. I installed the second one I bought and it works fine.
Paul in Hunt Valley
