Re: OTish: Material for Interior window trim?
NickB
>Windsor One is a great line of high end moldings, but if you aren't going high end (built up, large moldings), then you should be able to find what you need at a good lumberyard or one of the borgs (on the SF peninsula, there is a great door and molding place-I'm stuck with a lumberyard here in Eastern Mass).
If you can get good quality pre-primed MDF, I'd use that for casing material, but I'd go with poplar (or soft maple if you can get it at a reasonable price) for the window stools. If you can't get good preprimed MDF, look for good preprimed fj pine (if you can see the joints through the primer, it's not good fj material-no paint will hide joints that show through the primer). If the material is not backprimed, back prime before installation. If you can't find preprimed material, then see if you can find a source for clear pine.
I've been re-trimming the entire inside of my house, inluding replacing picture-framed window casings with stool and apron trim. I'm using 3 1/2 clear pine casing stock, which I mill into the trim I need (stopped fluting for the casing boards and a quirked bead for the aprons), and poplar for window stools, plinth blocks and rosettes. I use fj material where ever I can (saves money, and more efficient use of trees, particularly given that all of my new trim is paint grade).
I'm starting to see the end of the tunnel on my project-if we keep people out of the living room and dining room, the house no long looks like a construction zone!
Hope this helps,
Nick
