3-Wing Slot Cutters
3-Wing Slot Cutters
3-Wing Slot Cutters
Doug Reynolds in Seattle
>Does anyone make either a 5/16" three-wing slot cutter or, cutters that can be stacked to make 5/16"? The ones I have (unknown brand)and Whiteside cannot be stacked.
Re: 3-Wing Slot Cutters
Yes *LINK*
Lee Schierer - McKean, PA
>Freud makes one as a separate bit for cutting slots. They also make a stackable tongue and groove cutter set that will cut longues and grooves from stock thickness of 1/2" to 1 1/4" and groove widths of 7/32" to 3/8". The bit number is [FREUD 99-036] 1-3/4" Diameter Adjustable Tongue & Groove Router Bit Set with 1/2" Shank.
You can get both from Router Bit World.
Lee
Stackable slot cutter
Re: 3-Wing Slot Cutters *LINK*
waroland
>Here is one that does that.
Slot cutter
Yes, MLCS item #'s 310, 5350, and 7650
Dave Bair, Eaton Rapids, MI
