Any Leigh Superjig users out there?
DizD
>I've been cutting practice pieces and am having problems with variable half blind joints. Without going through describing all the efforts to date, here is a summary of the main problem. On a 5" board with two wide tails and two narrow tails, the half pins fit well but I'm usually getting a gap (about the size of the thickness of a business card to a credit card)in between 3 of the pin/tail joints.
Just wanted to see if anyone else had encountered something like this. Any other tips for setup which worked for you?
Re: Any Leigh Superjig users out there?
Doug Boor
>I'm not a superjig user, but I do use the D4. I had a similar problem with half blinds. No adjustment would fix it so I ended up calling Leigh for some tech support. They first sent me to my guide bearing to make sure it was actually the size it was supposed to be. That was fine, They then said that if everything was setup okay, the only other problem could be the bit, specifically the angle. Sure enough, using a none Leigh brand bit, checking the angle showed it a bit off. After I got some Leigh bits, never had a problem again. Fortunately, I had just gotten that bit so was able to return it and the others I bought. The only bits I use on my jig now come from Leigh. Never have had a problem since. Are you using an aftermarket bit with the superjig? If you can't fix it yourself, as I mentioned, Leigh tech support was great, answered all my phone calls and spoke to someone who uses the jigs all the time. The 8mm bits really do work better.
David Yoho
>Probably won't be any help to you. I have the 24" Super Jig but it's still too new to me to know about your issue. I've set mine up by the instructions and cut through dovetails so far and they came out nice. I'm not sure whether your finger scale needs an adjustment or if the E Bush will take that play out. Has the manual been any help in resolving this issue? Maybe a call to Leigh support is in order.
David
John McGaw
>I don't use the Superjig myself but this may still apply:
In using my D4 I discovered that my guide bushing was not precisely coaxial with the bit of my PC693. It wasn't off by much but if I made the mistake of rotating the body of the router relative to the jig while making joints I could easily introduce enough error to be visible in the final product. This was even more troublesome when making through joints using two different routers in an effort to save setup time. My final solution was to simply be careful not to rotate the router -- the label always faces me while routing -- and the errors became vanishingly small after that.
Right on John! Nothing can be more......
Art Silva
>frustrating when things don't fit. You pay the big bucks, and follow directions to the letter, but things don't fit. The answer over 95% of the time is to make sure the router base/guide bushing combination is concentric with the router bit/shaft. This is easily accomplished with either a centering cone or a guide bushing with the same inside diameter as a test straight bit. Tighten the router base and mark an arrow on the router frame at 12 O"clock.
Thanks all Re Superjig tips
DizD
>I'm using the Leigh bits and have been in touch w/ Leigh tech support, hoping for a "quick fix". NSL. I can get decent through dovetails, and have done 2 sets of "one pass" HB and both turned out ok. I'm in process of tweaking the router/E bush alignment to see if I can eliminate that as the source.
