Delta 14" Bandsaw motor
Wayne
>My Delta 14" band saw has a 3/4hp motor will it support a 1 1/2 or 2 hp motor? Has anybody done it? If so any problems encountered.
Wayne
Re: Delta 14" Bandsaw motor
Denis Ch�nard, Orl�ans, Ont.
>According to Louis Iturra, the Delta can take a 5 HP motor without problem. However, the saw frame is not stiff enough to properly tension blades wider than 1/2", and blades of that size do not gain anything from any higher than 2 HP, the blades can't clear the saw dust fast enough.
This said, I installed a 3 HP motor on mine, and at the same sped up the blade to close to 4000 FPM (from the base 3000, Iturra again says this is doable). The speed gain makes use of the extra motor HP, as the sawdust gets cleared faster.
This is the best thing that I've done to that saw, and it works like a charm. The only problem I encountered was that the standard guard would not fit over the larger pulleys, I made another one out of plywood.
DC
Wayne
>what pully did you change and what size did you use? I was thinking of 1 1/2 or 2 hp 1750 rpm. My saw has an open base type stand. To solve the problem with the guard could the motor rpm be increased to 3450 and reduce the pully size?
Wade Mackey
>I put a 1 1/2 hp motor on mine ~ 2 years ago. Ii made a real improvement . I did have to cut a notch in the lower door to allow for opening it to change blades.
Wade Mackey
>I kept the motor pulley, and switched the "driven" one from 4 1/2 to a 7 1/4" one if my memory serves me right. The motor swap involved going from a 1725 RPM motor to a 3450 one, therefore the required larger pulley, which doesn't fit inside the guard.
If you keep the motor RPM to 1725 you would need to increase the motor pulley diameter by 33% to raise the FPM on the blade to 4000. IIRC on mine the resulting FPM is about 3930. Who knows, that might fit inside the guard...
DC
BTW, I also had to change the switch since the new motor runs on 220.
Should have mentioned
>My saw is of the open base type, with the motor sitting on top of the base, not below like the enclosed based models.
DC
Switch?
Rod Peterson -- Ormond Beach
Was it the regulation red/green Delta pushbutton? That should be a DPST (double pole/single throw) and would handle 240V nicely. It's usually wired to switch both wires—hot/neutral in the case of 120V, hot/hot for 240V—so all one would have to do is hook up the motor, replace the plug on the end of the cord, and Bob's your uncle.
Moreover, as Rick Christopherson points out, a SPST switch is also perfectly fine for a 240V plug-in device, although it is counterintuitive to a lot of people.
Rod
Re: Switch?
>My saw is 12 years old or so (28-475 IIRC), and used a toggle switch mounted to the edge of the base. I re-used that switch somewhere (can't remember where right now), but from memory it was a SPST switch.
As for a SPST switch on a 220V motor, maybe it's fine, call me chicken but I'd rather have a switch that does cut all power to the motor and not only one leg...
DC
Alan in Little Washington (NC)
>I put a 2 hp motor in mine. Just barely fit in the enclosed base. Much improvement in resawing.
Re: Switch?
Paul Waddle
>You and me both Denis! I can see how a bare wire will get you 120 greetings with a SPST. At least go with a DPST or for exercise,go for the DPDT-one side won't do anything. ha ha.
del schisler
>here is what i done I used a 1hp 3450 With a 1" double belt browing pulley on motor And a 6" double browing pulley on saw Mine works fine del
Bill Earl
>I upgraded to a 1 1/2 HP also and had the same problem with door clearance. I relocated the motor to the underside of the base.
Calculating bandsaw blade speeds *LINK*
wilbur
>Here's a link to a calculator that will figure out the blade speed of a bandsaw blade, based on the RPMs of the motor, the size of the pulleys on the motor and bandsaw wheel shaft, and the diameter of the bandsaw wheel.
You'll find that there are many combinations of factors to get you to a given bandsaw blade speed. If you are looking to speed up your bandsaw blade speed, you have the choice of increasing the size of the motor pulley or decreasing the size of the bandsaw wheel pulley. However, trying to use pulley diameters as large as possible is generally better, as it will more easily transfer power from the motor to the bandsaw wheel, so of the two, I would increase the size of the motor pulley.
Bandsaw blade speed calculator
2 HP Baldor, 1/2" x 105" Carbide = WHOOPIE !
Art Silva
