Steaming Walnut question?
>Most of us know that commercial walnut is steamed to darken the sap wood and get more usable wood from the log.
I was wondering if anyone had tried it on air dried walnut? (I know, air dried is prettier, but) I have a bunch of air dried walnut and some of it has sapwood in it. I was thinking of small pieces like maybe a bowl blank or perhaps small furniture parts. Just wondering how much steam it would take and how long? Is it even possible? Could it be as simple as passing a steam iron over it a few times?
Re: Steaming Walnut question?
David Yoho
>I don't think this is a DIY project but maybe someone will have a better answer. I'd either include the sapwood like-is or try a dye to even things up. Personally, a little sapwood isn't a bad thing. I'm not a fan of a lot in a piece, though.
David
Ken Kimura
>Berry, I have a lot of air dried English Walnut and considered steaming. As I understand, steaming removes color so you can dye uniformily. I found you can also remove color by painting a solution of lye. In my case, I was trying to remove water staining that turned black and blochy. Search finishing articles for the formula. You indicate that you intend to turn and process the wood for smaller parts. Machine the wood to the final piece before steaming or bleaching. I like the contrast in color and usually try to incorporate the defect into my projects but if I find it just looks crappy, I wipe on "NGR Sapwood" without removing the original color. Looks ok to me but then I don't see so well. Ken
del schisler
>here is a what i found on the web form on steaming walnut del
http://www.woodweb.com/knowledge_base/Steaming_Walnut.html
boardman
>I believe steaming is done under some pressure and before the wood is dry. Not doable at home or on dried woopd as far as I know. It spreads the color to the sapwood, but also "dilutes" and homogenizes the color. The end product is awful looking compared to the rich tones and colors of air dried.
Re: Steaming Walnut
>Don't think you can get there from here, Barry. Steaming during the kiln-drying process tends to push the extractives and their pigments from the heart out into the sap wood and also relieves stress in the wood fiber. However, once the wood is dry, those extractives are mosty gone, and you'd have to rehydrate your wood clear to the core to get any real leaching to occur. We steam dry wood to heat up the lignin to soften it and allow bending and forming, it doesn't soak the wood to the core with water.
I'll second the suggestion to use a dye stain to blend your sap wood; I have done so effectively. If you do dye the sap wood, just be sure not to use that area as an outside edge where a dent or scratch will reveal the light color wood under the dye/stained layer.
mm
a contrary opinion
Bill Tindall, E.TN
>I encourage you to visit my article on steaming walnut in the Articles section.
the straight dope on steaming walnut
Bill Tindall, E.TN
>1. Steaming requires the temperature of the wood to get to the boiling point of water, or higher, in the presence of wet steam. Extractives don't move anywhere. When the sapwood gets hot enough and wet enough it turns nearly the color of heartwood. This transformation occurs within minutes.
2. I steam small objects in a canning pressure cooker at about 15 psi. Stuff comes out equivalent to commercially steamed material.
3. steaming is less effective when the wood has been dried.
I have an article in the Articles section on steaming .
Thanks Bill
>I was hoping you would weigh in on this.
Thanks Bill
>Guess the info I was given by the guy I bought wood from was wrong. But then he was an "air-dry" maven with the position that kiln-drying walnut wrecks the wood.
mm
