200+ woodworking book reviews
OT-Computer Help Needed
Martin from Granbury
>Working on the final draft of the kid's science report. Need to take some pics and put captions underneath them for the Appendix.
I can take the pics and get them to my computer, just don't know how to add them to the MS Word program. I have an older version, Office 2000, if that matters.
Worst case I can cut the pictures out and paste them on to other pages, but I am trying to help him make it look a little more neat.
Thanks for any suggestions...
Martin
Re: OT-Computer Help Needed
JohnKJordan in East TN
>Open MS Word help from the menu (or press F1), type 'picture' into the index, and look at the topic "Insert a picture from another file". (give a man a fish, and all that...)
One unsolicited suggestion: If you are doing this for him as your message implies, consider letting the child do all the steps of placing and formatting the photos. It may take longer and the result may not look as neat but he will learn far more that way, and the confidence gained will be priceless. What I always did was figure out the process ahead of time (if necessary), then step back and let the kids do everything, providing guidance as needed.
David Yoho
>This is fairly simple to do -
1. First, save the pictures to your computer (remember where you put them).
2. In your Word document when you position the cursor where you want the image to go - click on Insert from the top tool bar.
3. In the drop down list that results, click From File.
4. An Insert Picture window will appear, which will allow you to navigate to the images you saved earlier. Using the mouse pointer, click the photo you want and then click on OK.
5. That's all there is to it, you're done!
I still use Office 2000 but my wife uses 2003 on her computer. I figure if it ain't broke - don't fix it. She uses that version at work, so she needs it sometimes when she brings things home. I don't have that problem and always liked 2000 the best, so I'll keep using it until there's a real reason to change.
David
Thanks to both of you!
I do this every day…
Rod Peterson -- Ormond Beach
>Well, maybe not every day, and not the slew of pictures you're talking about, but every letter I write I add a jpg of my signature I created several years ago. As was indicated, place the cursor somewhere near where you want the picture, click on Insert in your tool bar, move the pointer to Picture, then click on From File. A box will come up which will allow you to select the directory in which you put your pictures, and will show thumbnails of the pictures you saved. Highlight the one you wish to insert and click on Insert to place it in the document.
That series of steps gets the image there and if you left click on the image, you will get an outline with little boxes in the corners and on the sides which you can use to dimension the picture to the size you want. If you want to move the picture, right click on the image and select Format Picture from the choices given, then click on the Layout tab. Pick one of the choices other than the default (In line with text). I use In front of text with my sig, but Tight may be the better choice for your application.
The picture will then have a different outline and when you move the cursor over the pointer will change to a cross hair sort of reticle and if you then left click and hold on it, you can move the picture wherever you want (and still dimension it).
It sounds complicated when written like the above, but will become second nature after you try it a few times.
Rod
Ron Jones
>Well made point John. The whole idea here is for the student to learn.
Jerry Nicholson
>Office 2000 is an "older" version? I am still using Office 97, both in Windows XP and in Linux using Crossover. Works for me!
Jerry
Re: Yeah
Dave Arbuckle, Plano, TX
>Current version is 2007, and I daresay you wouldn't recognize anything about it compared to your version. ;-)
Re: Yeah
Carol - now in NC Nebraska
>That is true. But it grows on me. Now if I could just figure out how to make a different style the default style....
Upgraded from 2003, but have to use compatibility mode or others cannot read my files.
Re: Yeah
Jerry Nicholson
>>>>>>Current version is 2007, and I daresay you wouldn't recognize anything about it compared to your version. ;-)<<<<
Yep - good reason not to change! And my old version doesn't require activation.
Jerry
Re: Yeah
Word has always been prejudiced toward the style named "Normal" being the default one. There might be a way to get it to act otherwise, but being a get-along type guy I just make whatever I want my defaults to be, be the Normal style.
The super quick and easy way to do that is to format some text the way you want the default to be, highlight it, then right-click the Normal style on the speedbar (or whatever they call it) and choose "Update Normal to Match Selection".
I just realized that I've been a Microsoft Word user for over twenty years. Started on the DOS version that was still a MS proprietary interface, like MultiPlan. Moved to the DOS version that started acting like Windows programs do, taught that one in adult voc-ed, taught Word for Windows version 1... Wow. ;-)
Re: Neither does OpenOffice
Glenn Madsen near San Francisco
Jerry Nicholson
>I could get along with OpenOffice but I prefer Office97 and already own it. Some of my Excel spreadsheets (the ones with graphs and/or macros)would have to be rebuilt to play well with OpenOffice. You certainly can't argue about the price of OpenOffice.
Jerry
