Saving money heating your House (or Shop) (OT)
>There have been posts here about high heating bills in homes and shops and I posted a few tips. Someone asked for more, so here they are again. (Really, they did ask, but I won't mention the name, I will take the blame for babbling, Wasting the band width.)
This could stretch out to several books, so I will try to keep it fairly simple, straight forward, and short. If you have questions, ask, if you have better ideas, suggest them.
After a building is reasonably well insulated, the next biggest heat loss is Air flowing through the building. Warm air rises and tries to exit through the ceiling. When it escapes it draws in replacement air though the lower part of the building. (the floor)
So, look for any holes through the floor and ceiling and seal them up. The holes left through the tops and bottoms of walls by electricians and plumbers may add up to leaving a window open or having a broken window pane. Before you insulate the floor, take a caulking gun and seal any hole you can find. (same in the attic.) You can stuff the holes under the bath tubs with fiberglass. Look for voids or openings around pipes and ducts and seal them with Great Stuff like foam, or chink them with fiber glass. This is grunt work and nasty, but really cheap if you do it yourself. If you reduce the vertical air flow through your house it will pay off in comfort and energy savings. If you spend $50 on this it will probably pay off in the first year.
Insulate the water heater. The jackets are cheap and they work. Be careful on the gas units and don't get it near the burner door or the vent on top or cover the the inlet vents on the newer units. Insulate the hot water pipes and the first few feet of the cold water pipe at the WH. (On the older units water could circulate out into the cold pipes when the unit was sitting, not in use).
Install low flow shower heads or flow restrictors. Take shorter showers.
To reduce that loss associated with windows, caulk around the inside of the windows, caulking the time to the walls and to the windows. It's a long story, but it is more effective to put the caulking on the inside.
Switch to the Compact fluorescent bulbs and LED bulbs. They do pay off.
Look for Insulation By-Passes. These would be holes through the insulation into voids in the construction. Things like the hoe through the floor under the bath tub, mentioned above. In the attic, it might be holes down into cavities where ducts run vertically form floor to floor. Sometimes these run all the way from the basement or crawl to the attic. Cold air falls into the hole, saps heat form the often uninsulated surrounding walls and rises back into the attic. A thermosyphon, syphoning heat out of your house. Some of these are stunning and you might discover some wasted space you can make use of. At the very least you should sell them at the top and bottom to resit the air flow. You can use most anything, Cardboard, plywood, Sheetrock, whatever will work. Remember you are trying to stop airflow, so you should cut these pieces neatly and caulk them into place. Insulate over them. Look down into the tops of stairwells from the attic, they are often poorly insulated or not insulted at all. This goes on and on. Cracks around pipes and chimneys etc.
Watch out for recessed or "pot lights". Many of them are "open" and rely on having heat flow/air flow through them to resist over heating. May not be wise to seal them up and most of them have instructions that say to keep the insulation back three inches all the way round. You could use a piece of duct work to set over them to allow you to insulate as best you can. It would be wise (But expensive) to change to the ones rated for direct burial in the installation. If they were mine, I would use Compact fluorescent bulbs and put a five gallon bucket over them in the attic and insulate over that.
If your ducts are in the attic, you can cover them with insulation.
If you do the work yourself, you can do all of the above for $200+/-
and it might pay off in a year or two. In some cases, big time.
If you have thin insulation in your ceilings, add a bunch. At least R-19 in the deep south and R-38 and higher further north. Check with your local utility to see what is recommended for your area.
Your floor might be the next candidate. consider increasing it to about R-19.
You can improve your windows by covering them with film. Effective, if a little tacky. You can also use your window shades for insulation (pleated shades). Many opportunities here, lined drapes, etc.
Back in the attic, look for dirty insulation. If this dirty it might be because air is flowing through it and the insulation is acting as a filter. Find the crack or holes and seal them.
If you have an attic hatch, weather strip the opining. If you have a door to the attic, weatherstrip that. If you have a pull down stair, make a box of Styrofoam to sit over top of it like an insulated hat and weatherstrip the box to the floor. (A friend did this after years of prodding. His hall had always been cold in winter. After he did it, the hall "warmed up" so well that he did it for his daughter and several friends.)
Most of these things will work and will pay off financially. I suppose they are "green" and good for the planet, but I look at things for saving money/energy more than just being green for the benefit of the environment. They should do both.
And one Don't or at least it a caution. Don't install replacement windows for the sole benefit of saving money. Somebody will prove me wrong, but I have never heard anyone say they saved anywhere near the promised savings.
