OT Car Electrical Question?
>I have a 2003 Honda CRV. It has an Auto-up and Auto-Down feature on the driver's side window. You can "click" the button and the window will go all the way up or all the way down. I like the feature. (How lazy does that make me?)
When ever the battery goes dead or you remove the battery, it loses this feature and I would take it back tot eh dealer and they would reset, at no cost, except for the PITA aspect of going and waiting.
I have discovered that if you just drive the car for a few days, the feature reappears. Apparently it resets itself. This time, it took about four days. Does anyone have any idea why it would do that? What would cause it to refresh or whatever after a fairly long interval? I don't really care, but it would have saved me a few trips to the dealer if I had known and it is curious.
Re: OT Car Electrical Question?
Rick in WNC
>Barry,
I have no way to test this fix I found for your window issue but it may just work:
"To do this reset turn the car on but do not start it, make the window go up and down like 3-4 times on the 3rd or 4th time hold the button down for 5 seconds when the window is all the way down, do the same when the window is all the way up. Turn the car off then start it like normal and it should work just fine."
Rick
Carol - now in NC Nebraska
>Thanks!
I had the same problem with my Odysee. Now I know what to do. Or at least try.
John McGaw
>I just have to ask, with a 2003 vehicle why would the battery be going dead or require replacement? I'm used to getting at least 10 years of life from my OEM batteries even when it is something like the tiny one that my 1991 Miata had hidden in a corner of the trunk.
>Good Question. Wouldn't I like to know! Ther battery in it is the third one. Been in the shop over and over for this and they have given two free. They say they can't find the problem.
Howard Norman
>In the Phoenix area car batteries last two to three years was my experience for the last 30-40 years.
Howard
Kneale Brownson awaiting snow in N. MI
>My guess would be the voltage regulator on your alternator is overcharging the battery.
Odyssey question, Carol...
Bruce, a MN Galoot
>I'm thinking about a used one in the next year or two and have been looking for someone who owns one. How do you like it? Any problems?
Thanks
Bruce
>I was in a hurry when I posted that, so I cut myself short. I have two rechargeable Maglites that ride in chargers in the car. The dealer is fixated on them. Insists that must be the problem. I point out that they have been in every car I have had over the last twenty years, including the 97 CRV I had before this one. (between my son and I we drove that car 275,000 miles over nine years and had two batteries.)
Every time I take the 03 CRV in they check it for parasitic or sacrificial losses and can't find any. They ruggedly gave me the third battery with the comment, this will be the last one.
They car has had some other electrical "problems". The key gets hot to the touch. Almost too hot to touch. Dealer thinks its normal. They replaced some sort of module in the steering column on a recall. And the swivel in the steering column that carries the wiring to all the stalks went bad. I made them pay for that, even though the warranty was expired.
Next time I leave the car sitting for four or five days, I think I will unplug the Maglites to see if that affects it.
JohnKJordan in East TN
>One of my jeep cherokees went through three replacement Optima batteries, each failed after some months. I discovered my son was sitting in the car playing the radio during his lunch break at school every day. Quit that, and the last battery worked as expected.
>..."this will be the last one."
Can they get away with that? Contact Honda corporate. That worked wonders for me with GM and Honda both (Honda once replaced a blown engine in one of my motorcycles that was at least 3 years out of warrenty.) If you kept records, you also might check into the lemon law for your state.
Re: Odyssey question, Carol...
>I love it. It is the most comfortable car I have driven or ridden in. It gets decent gas mileage (20-24). I bought it for 2 reasons. I could (if I had to) get a 4x8 sheet of plywood in it. (have to remove the middle seats and scrunch up to the steering wheel, but then I am vertically challenged!).
My previous vehicles have all been pick-ups. I loved my trucks, but the reality is the mini-van is more useful and the mileage is tons better. Only normal maintenance on the mechanicals issue.
The Oddy has always gotten great reviews and has perennially been rated the "best" van.
I added (third party) a tranny cooler and a PS cooler. Factory required for towing. Gas mileage tanks when towing but then how much does one do?
Would I buy another? In a heart beat! In the 3-1/2 years I have owned it, I borrowed a pick-up twice for hauling something. I can live with that, even if I had to rent a truck.
My 2 cents.
