Resaw blade question
Scott Burr in Ben Lomond CA
>Hi All, I hang out on the hand tool side of WS but I need some help from the collective over here.
My Timberwolf 1/2" 3 TPI resaw blade has finally bit the dust. I liked the Timberwolf blade, but there are new blades out in the world now. Lenox, Woodslicer, etc.
Do or have any of you used these? How do they compaired to Timberwolf blades?
My BS is a 14" Delta with a riser.
Cheers,
Scott
Re: Resaw blade question
Tony - Memphis
>I have a jet 14"/riser kit. I have been using the Highland Hardware balde (Woodslicer?). I have been real happy with it. Before I go the riser kit, I used the Timberwolf and it was a real nice blade too. I couldn't really say one was better than the other, but I have used the Highland blade more and it has always been great.
Tony
>I have only used the Woodslicer from Highland Hardware, so I don't really have a comparison (HH used to be a 34 mile round trip). I like my Woodslicer fine.
Re: Resaw blade
>Tried a Lenox once and a couple of other generics in place of my usual T-wolfs; didn't like them, gave the Lenox to a friend who used it. I find the Suffolk blades cut more smoothly, especially in cuts over 4" thick, and seem to hold their set better/longer.
Can't speak to the Woodslicer.
mm
I'm cheap
Bill Tindall, E.TN
>I go to the local saw shop and have them custom weld my blades. As long as the blade is 1/2 to 3/4", 3-4 tpi, and sharp it resaws just fine. I think the blade stock they use is Lenox or Starrett blades for cutting wood. I don't seen any significant difference in these blades vs the hyped variety that cost more.
Lenox 3TPI carbide
Ken Kimura
>I bought a 2-3 variable pitch bi-metal from Suffolk Machinery back in 2003 thinking I would give it a try before moving on to carbide. I've cut a lot of mixed hardwood and softwood from 6" to 14". I just resharpened the blade last week and I'm back to cutting. I'm very happy with this product. It's more expensive than the silicon steel blades but less than carbide. Ken
I'm really, really cheap
John in New Mexico
>I make my own. Last time I bought blade stock, maybe three years ago, it came out to around $3 per 1/2" blade. Probably more now, but still relatively cheap. I silver solder the blades - they usually dull before they break - though not always. I've got a blade welder a friend gave me, posted a pic maybe 6 months ago. When I need some new blades I'll get that fired up and do them "right".
Thanks for all your input!
Scott Burr in fridgid Ben Lomond, CA
>The Trimaster looks real nice but, at $120.00 for my saw Yow! I went for the 30 buck woodslicer a new set of tires and ball bearing guides. Still under %120.00, money well spent IMHO.
Thanks again for all your input!
