Milk Paint
Milk Paint
Milk Paint
Tomm
>I just tried some milk paint on a few Shaker boxes. The paint was easy to mix and use but I was surprised that the manufacture recommended a clear finish top coat. I used equal parts of boiled linseed oil, poly, and thinner and then applied. I was not happy with the results because it needed another coat. I was wondering what other people use as a top coat. Thanks for your input.
Re: Milk Paint
Re: Milk Paint
Dennis Yoder
>two or three coats of milk paint and finish with microcrystalyn wax. Sanded if wanting to have the distressed look. Dennis Y
Re: Milk Paint
Re: Milk Paint
Charles Yawn
>Tomm, I am just getting into making shaker boxes. I will monitor the responses about your milk paint question with interest, but I wanted to ask what kind of wood are you using or have used to make these boxes? So far, I have only used cherry (with good results) and am interested in the experiences of others. Thanks. Charles
Re: Milk Paint
Re: Milk Paint
John McGaw
>After a few experiments I determined that clear satin water-based poly is a very easy topcoat for milk paint. The kicker is that it is something that I've always got around the shop.
Re: Milk Paint
Depends on what you want
>An oil-based topcoat mixture like the one you mentioned will darken and saturate the color of the milk paint. It will also largely soak in without building appreciably, so if you're after a film finish for some reason, you will have to apply several coats to build up a luster. If you want a thicker film, I'd suggest a brushing varnish, though I am not convinced that Shaker boxes need this amount of protection.
Waxes and waterbased polyurethane will leave the color of the milk paint closer to its original color.
Ellis Walentine, Host
Re: Milk Paint
Same here...
John in New Mexico
>We're finishing our kitchen cabinets with milk paint. The black for the island gets a couple coats of Waterlox for a nice satin look and really easy application. The other ones are salem red, and not wanting the color to darken we're using blond shellac to give it a similar sheen to the island without darkening the color. Personally, I've never found any finish that gives the results I'm after in a single coat.
Re: Milk Paint
Re: Same here...
Dave Dewees
>I generally put on two to three coats of milkpaint (Original) - lightly buffing with sandpaper , 3m or steel wool between coats. I've used tung oil but lately Watco Danish oil which dries fast between coats (2-3)then buff out with 000 steel wool. Love the look. I'm in the middle of building and finishing my kitchen cabinets - light cream. The oil protects and gives it a soft, aged look.
