Disassembling oak cabinet doors
Dan Mitchell
>Our kitchen has commercial, raised panel oak cabinets. I would describe them as middling quality (for example, the drawers are constructed of stapled white melamine board, not dove tailed hardwoods). I want to replace the raised panels in 7 of the cabinet doors with glass. I'm wondering if there is a relatively easy way to get the doors apart at their glue joints, without any splitting, to enable me to remove the oak panel & reassemble with a glass panel. I also thought of carefully cutting the inside protrusion of the groove which holds the panel away on the table saw, by carefully raising the blade to the proper position with the panel on the saw, then cutting (I hope I'm describing this clearly). I see though that there are flush nails here & into the groove from the inside holding the panels & I don't want to ruin my blade. Any ideas?
Hope everyone had a great holiday!
TIA
Dan
Re: Disassembling oak cabinet doors
Lee Schierer - McKean, PA
>I would think that you would have better luck cutting away the inside lip with a router so you could see what your are doing. It would leave a radius in the corners, but that could easily be removed with a chisel.
You will need to match the existing stain color with a new strip of wood to hold the glass in place or you culd attach it in the frames with silicone.
Lee
Dan Mitchell
>Thanks for the quick reply. I thought about using my router, but not sure how I'd guide it. Too close (I think) to the edge to use the edge guide. Could clamp a guide bar down the center to ride on the inside edge of the router foot, but the rear of the panel is below the surface of the panel rails. Have to shim the router base on the inside...
Dan
Dan Mitchell
>Just looked at this again, the rear of the panel IS flush with the rear surface of the frame rails, so it looks like a router is the logical way to go!
Dan
Re: Before i had a shop & power tools
john b. southwest Chicago burbs
>The method that i used was with a steel straight edge, clamps razor knife and a wood chisel. Scribe all around with knife, make sure corners over lap about an 1/8",trust me, then carefully use chisel. Once you get the hang of it it goes pretty fast. Buy or make molding to hold on glass. john b
Dan Mitchell
>Thanks John. I had thought about using a chisel, but was afraid of splitting. Scoring 1st & a straight edge clamped would help. Might be the quickest approach & less concern over nails.
Dan
Larry Clinton At Frankfort (Central)., Indiana
>Dan, If I were doing this I think I would make some open patterns out of scrap & use a router with a guide bushing. IE: if the panel (total size - not just the exposed area) is 12" X 16" I would make a frame with inside dimensions of 12 1/2" X 16 1/2". By centering it over the area to be removed, and using a 1/2" bit with a 3/4" bushing, it would be an easy task to make an exact cut to remove the area holding the panel in place. Don't know how many different size panels you have to remove, but shouldn't take lone to make a frame for each. If you start with the largest ones, you can cut the frame down and reuse the parts. With very little chisel work in the corners you should be able to insert the glass and either make or buy a molding to hold it in.
pecker
>In American Woodworker magazine of May 2004 there is an article to do this. To remove the panel, they just drilled a hole near each corner, then jigsawed most of the panel away. Pulled out the remaining pieces with a pliers.
Then they used a bearing guided rabbeting bit to mill away the back of the frame for the piece of glass. The bearing rides on the inside lip of the frame.
Ken Krawford
>There was a recent episode of This Old House where they did something similar with a door. Silva made a template, clamped it to the door and used a guide bushing in a router.
Dan Mitchell
>OK, this is one of those "why the heck didn't I think of THAT" moments. Seems like the most straight-forward approach, especially given the presence of the small, hard to locate bit-destroying nails.
Thanks for all the helpful replies!
Dan
Just did the same thing.
John Cotten
>I co-op my cabinet shop with another cabinet maker. Ira just did what you describing. He is literally finishing a door job where the customer wanted mulloned doors from solid panel factory doors. Ira took a PC router his PC straight edge guide and set it to cut to the back side of the dado the panel is located in. He used a 1/8" spiral straight bit and adjusted it to 1/32" above the panel. He then routed out the back of the dado to expose the panel and created a rabbet for the glass to set in. He did this on 8 doors.
Be careful using a guide bearing bit.
John Cotten
>Ira originally was going to do the same thing. The front molding profile has a thumbnail type profile. There would not be anything for bearing to accurately ride to use the rabbet bit with a bearing to not risk damaging the door or door profile on the front.
