Applying Lacquer over paint
Francesca
>I just the article on applying lacquer under finishing secrets in "Russ's Corner." I have one question: how would the steps change if I wanted to paint my cabinets with oil based paint before applying lacquer?
Thanks!
Re: Applying Lacquer over paint
The Steps Change To . .
>Don't bother.
If you don't have trouble with fish-eyes, you're likely to have checking and cracking of the hard lacquer over the relatively soft paint layer.
If you want a painted surface, than leave it alone. If, however, you want a pigmented coating with a lacquer film, use . . colored lacquer. It is available in many colors and can also be custom mixed to whatever color you want.
mm
PS
>Forgot to mention the 2-part automotive lacquer "systems" where you apply your color in a flat base coat and then go over that with the high gloss clear coats to build depth. Candy apple red, perhaps?
If you want the color yet want to keep the look of wood grain, consider using dye stains instead of paint (many available in very strong colors), and then apply your clear over that.
mm
>A practically foolproof, easy, and inexpensive way to get a great looking pigmented finish under clear lacquer is to basecoat with a high quality acrylic latex flat interior wall paint. Several coats, brushed on and leveled with 220 paper (if necessary), dried for a week or so, then top coated with a spray acrylic or alkyd lacquer.
An alternative is to have an auto paint shop mix a basecoat to your color, and do a basecoat-clearcoat procedure.
Though it's possible to do a lacquer overspray on top of an oil enamel, it may be problematic, and I would avoid it.
Clint
>Example of the first way
Advantage?
>Hey Clint,
What advantage do you see using the latex base coat over straight pigmented lacquer? I've had good results using tinted glusize under colored lacquer, especially on MDF and thin veneer ply.
Am I correct to assume you're using an acrylic top coat to maintain a water-white clarity and avoid the slight ambering produced by most NC lacquers?
mm
Re: Advantage?
>Mark, I do it both ways; kinda depends on the project. I recently rebuilt and refinished an upholstered Victorian loveseat with a lot of exposed carving. I changed the nondescript brown stain to a pearl metalic, using all alkyd lacquer that I mixed from metal and pearl powders. A current project is a child's dresser, made of baltic birch, that's going to be done with water white alkyd lacquer over flat acrylic latex in a color of the customer's choice. She (my 750 mile away daughter) will pick the color from a Borg sample that I'll get a quart of with less hassle and expense than getting a lacquer base coat to match. The acrylic latex also serves to fill the wood grain, for a more Oriental lacquer look.
I hope this answers your question.
Clint
Correction
>On the loveseat, I did use a latex acrylic as a primer under the lacquer to fill and even out the surface.
Re: Alkyd Lacquer?
>Not familiar with that finish. [just shows how much I really know] Alkyd varnish, sure. Alkyd resin poly urethane and oil-based paints, yes. But Alkyd Lacquer is a new one on me; especially water clear.
Brand name? Source?
Thanks
mm
ps: nice job on the couch
Re: Alkyd Lacquer?
>Mark,
My current favorite is Sherwin Williams solvent lacquer
Sher-Wood
Moisture Resistant
Medium Rubbed Effect
T70 F 22
530-3177
Alkyd
Beautiful even finish that needs little to no rubout. I usually give it a gentle rub with 0000 steel wool and Butcher's Wax for the final touch.
Clint
Thanks
>I'll look into it. That is if it passes New Jersey's VOC regs |;-{
Clint, would a spray coat of Seal Coat Shellac
Art Silva
>accomplish the same for less dollars?
Re: Clint, would a spray coat of Seal Coat Shellac
>Art, I'm pretty sure that a shellac barrier coat over oil based enamel would keep the enamel and lacquer from reacting IF the enamel was already well cured. But that adds another layer of complication and potential trouble that I would avoid by going the latex acrylic route, which I've never had a problem with. If the enamel is already laid down, I'd first consider a water borne poly or lacquer.
All this really begs the question of why a clear coat over oil enamel. A good oil enamel like BenjMoore Impervo is tough and shiney to begin with.
Clint
Jason Roehl in Lafayette, IN
>I think there's a distinct visual difference to the depth of color between a solid-color system and a base-coat/clear-coat system. It just depends on the application and the beholder's eye.
Jason
And that's where Beauty resides
