Over the years we have acquired some older maybe 30 - 80 year old furniture, nothing super valuable but none the less stuff I would like to make a time investment in. The items include a mahogany (I think) dining room table with chairs with buffett, a Governor Winthrop Type desk, and so on. I have no idea what they are currently finished with.
My question is how to maintain and revitalizing the finishes. All of the items are in finish wise good shape but the finishes are kind of dirty (light black gooey dirt), dull, hazy, and generally showing their age. I don't want to do anything destructive, like stripping, if i don't have to. And frankly if that was required we will probably wait. We are not looking for that brand new shiny showroom look, but the items certainly look better than they do now. What should I do to these items? What might i consider? I realize there will be many options.
A few nights ago I took a leg from a catastrophically broken dining room chair, wiped it down to cleaned it up with 000 steel wool and mineral spirits then tried it little tung oil. I must admit it looked pretty good. Is this durable? Would this be a good route to consider?
On a separate but related question, how does one deal with structural or loose glue joints? All of the chairs have loose joints which occasionally pop free or are otherwise loose. In my test case chair got the entire chair apart with a rubber mallet in about 5 minutes with no additional damage. I was thinking I could disassemble each chair, clean, finish the glue it up again. This seems more sane than a constant fixing and risking another catastrophic failure? What should I assemble with Carpenters glue, epoxy, or gorilla type glue?
Sorry for all the questions at once! Any and all advice will be greatly appreciated!
>Can't comment on the finish, but I would put the chairs together with hide glue. There is a good chance that they will come apart or break again in the future, and if you use hide glue, you can get them back apart to fix them. With the other types of glue, if a part breaks in the future, you may be out of luck for repairs.
>Barry, if the finish is good, here's a procedure I learned from a professional restoration guy many years ago that works every time. Best of all, it's as simple as falling off a log!
You'll need to gather up several items. You'll need some #0000 steel wool, some rags (old T-shirt material is fine), a soft rag to buff with (old fleece or sweatshirt material is great or a buffer and lamb's wool pad is even better), a can of Briwax (clear or one of the colored varieties but clear is good), latex or vinyl gloves, and the special thing that makes this work so well - DL� Permatex� Blue Label� Cream Hand Cleaner.
You can usually find the Blue Label hand cleaner at Auto Zone but I've also found it at Duron Paints and other locations. I've included a link below so you'll be sure to get the right stuff. This hand cleaner has no abrasives or anything else that will damage the finish. What it does is clean away dirt, grime, and grease. Just wipe it on with a cloth or steel wool. You don't need to scrub if you use the steel wool - just rub with the grain using only the weight of your hand as you do. Wipe away any remaining cleaner and allow it to dry overnight.
The next day, apply a thin coat (don't get carried away with this step as it's harder to remove a thick layer) of the Briwax. Whatever the hand cleaner missed, the Briwax will get. Let the wax set for about 15 minutes and then wipe it lightly with a clean dry cloth. This will remove any excess before buffing and make buffing go a lot easier.
Trust me, you will already see a big difference but you're not home just yet. Now you need to give the furniture a good buffing. If you don't have a buffer then a soft clean cloth and plenty of elbow grease will do. After buffing, stand back and admire your work.
I've used this procedure several times in the past when customers have brought me old furniture and said it needed stripping. Not only were they pleased with the results but were very happy they didn't have to pay me for a strip job!
