OT Tree Question
OT Tree Question
OT Tree Question
Howard
>Meeting with architect to design garage shop. It will end up within 4 to 5 feet of a mature 100' tall red oak. I really hate the idea off cutting it down. Anybody know if excavating the footings, which will cut through roots, would damage the tree to the point where it would be a hazard?? My other thought is to find a sawyer with a portable band mill and turn this into cabinets/furniture. Appreciate your thoughts.
Re: OT Tree Question
Nat Robison
>A few years ago, the county realigned the corner near my house, widening the road and installing cement curbs. The curb is now probably 10 feet from 2 mature red oaks. They seem to have come through it ok. 5 feet away might be another story.
Their original plan was to remove the trees (they're in the county's right-of-way) but received too many complaints about the de-foresting so they left them.
Dale Lenz
Dale Lenz
>Howard,Removing 1/3~1/2 the root mass of a tree is flirting with disaster. Any chance of putting piers in the soil ever so often, on the root side of the shop. Would think the Architect would think of that if possible. As a forester that does several house calls a year, I'd think the safe approach is to remove the tree with the lest amount of cost and get some lumber out of it.
Good luck
>This is an economic question. What will it CST you to remove the tree now VS. after you build the garage and the tree dies. If the difference is not great, you can leave the tree there and wait and see. IF the difference is vast (or even half vast) you should consider removing the tree first. Very good chance it will die. What is being lucky worth to you?
Jesse Cloud
>A friend of mine kept all the oak trees cut down where he built his house and used the lumber to make all the trim for the house. It drove his wife nuts because it took about two years of drying and weekend warrior trim work to get the house trimmed. But in the end they really liked it.
On the other hand, when I used to have a 100 foot tree that close to my house, I would cringe every time the wind came up. Don't miss it a bit.
Glenn Madsen near San Francisco
>Is this your only tree?
Does 'mature' mean close to the end of its life? Is it otherwise healthy?
Can you move the shop reasonably to accommodate the tree?
What will the property look like without the tree there?
All reasonable questions.
Check your email Howard
Scott in Eastern Iowa
Thanks Everyone.....
Howard
>My sense is the tree will have to be removed, but I will check with my tree guy to see what he thinks also. Thanks for your good comments
Tom Dunlap
>Yes, the footings will cut off a lot of the roots.
Do some reading on "critical root zone"
This is also an excellent book to read through:
http://www.extension.umn.edu/distribution/housingandclothing/DK6135.html
After reading the U of MN book you'll know if your architect and treeguy know about construction damage.
Gary Johnson, who wrote the UofMN book has said that there are red oaks that will die if you say 'Bobcat' too loud. Some species are more tolerant of construction damage than others.
There are many options that could be pursued but you'll need a very well educated arborist to work on the tree. many trees will survive construction because they were taken care of before the first shovel went in the ground. And!!! the post construction plan was in place and followed.
This plan could include some subordination of larger,heavier limbs. DON'T ever confuse subordination with topping.
Write to me if you have any tree questions. I've made my living as an arborist and my hobby as a woodworker.
Tom
