looking for "Shell" pattern for carving
Wayne
>Is there a geomentry to the layout of shell carvings. If so does anyone have it, or know where I can get it.
Re: looking for "Shell" pattern for carving
Ed Mulligan, Cape Cod
>There are different kinds of shells and so there are different requirements for layout.
Nora Hall sells a video and replicas on her site for a Newport shell. Mack Headley has an article on shell carving in Fine Woodworking # 61 that goes into layout.
Ed
Re: thanks
Wayne Carson "TX"
Lee Grindinger
The shell game
Lee Grindinger
>Layout of shells is fairly simple. Do a full scale drawing using the width of the lobe on the perimeter as your starting point. A full scale drawing will show you which width looks the best and then step these widths off around the perimeter. All the lodes should end in the same width so it's not compass points that determine the angles unless it's a perfect semi-circle, which some shells are. In shells that are elongated forget compass points and work with lobe width along the outside. It looks wrong for these widths to vary.
I'll attach pictures two very different shells of two very different shells to illustrate.
The pic above actually shows both types of shells, the center one is a semi-circle, the ones on top of the legs are elongated. Below is another example of an elongated shell, note how the widths of the lobes on the outside are the same in both the inner and outer shells, this is what makes a good looking shell no matter what the contour of the lobes.
If this isn't clear ask follow ups and I'll try again,
Lee
