>I have a problem with my bandsaw I have not encountered before. I have a 14" cast bandsaw with riser. When resawing in the past it has sliced up to 11" boards without problem. Now The blade at the bottom of the cut either bends toward the fence or pulls the bottom of the board away from the fence- not sure which. I have a feather board holding the bottom edge but it it does not seem to help. Even when I feel I am holding the board tight to the fence, the top of the cut looks good but the bottom takes a sharp bend toward the fence. I have a 1/2" timberwolf low tension resaw blade. Not much time on it. It cut perfectly the last time used. Roller bearing guides top and bottom. Is there some geometry I am missing here? It almost seems impossible that the blade can bend that much near the bottom guide. Tension- high or low- does not effect this problem.
>Mike, this sounds like it could be a "drift" problem. Were you cutting anything different than the last time it worked good? Sometimes wild grain can "move" the blade (make it wander) as it cuts. Also, it sounds like you're using a fence and if it isn't set for the drift of the blade and saw, the issue you're seeing could be the result.
Usually only a couple of things cause the problem you have.
1. dull blade, even with a newer blade if you've cut nasty wood or mdf it could be dull. Check that your guides are set correctly and not rubbing against the teeth a dulling them. If you have a fresh blade try it and see what happens.
2. inccorect tension, seems like you have ruled this out.
3. drift correction is set wrong. I wish I could easily explain how to set this but here are two explanations one from Paul Anthony and the other from David Marks
>It sounds like your blade is twisted between the top and bottom blade guides. Stick a SS ruler into the blade guides and see what direction they point. The same? I'm assuming here that you have the blade's teeth pointed in the right direction, your wheels align co-planarly, the wheels are square with the frame, the frame is square with the table, the table is square with the fence, and the blade has at least SOME set. If you're using a home made fence; is it flat (perpendicular and parallel). You can also re-set the blade to crab through any screwed up combination of machine mis-alignment.
>I'm thinking you believe nothing has changed since you successfuly resawed a wide board-well,something has changed. I would think the blade got a little bit dull& possibly the table tilted just a bit.You may want to run the pc across the jointer to insure the edge is square to the face. If everything is adusted properly,the only explanation is the blade if you didn't change the tension. You might try the single point guide,but I'm not sure what that would prove if you didn't use it before. Let us know,my main problem,simple as it sounds,was the table vibrating out of square with the blade and fence. pw
>Sounds like a blade problem, I'm betting a few teeth have lost some of their set which will pull the blade in the opposite direction; the thicker the wood the further it will pull as it travels through the stock.
I'd suggest you try a new blade, and watch where your guides are set to keep them behind the teeth when the blade is under cutting tension i.e. riding on the thrust bearings. I've seen several bands ruined because the guides were set, but when the blade got pushed back against the thrust bearings, the guides were rubbing on the teeth. As the blade heats in a cut, this took some of the set out of the teeth, and the blades wandered and pulled.
