Jointer and surface planer?
coontracker
>Just wondering what you guys like in the way of jointer and surfacer out on the market? Really looking for one I can put on a dolly to move around because of the size of my shop. Thanks!
coontracker
Re: Jointer and surface planer?
Howard Norman
>I have the Grizzly G0490 8" jointer and am satisfied. However it is not small. My planer is an older lunchbox unit and I have problems with it. The newer ones apparently are much better.
Howard
>Some jointers (Steel City 6" Deluxe Jointer and 8" Industrial Jointer) have built in wheels to move them around - you can buy mobile bases for the others. I don't know if I'd trust a mobile base for anything over an 8" jointer or for any of the really heavy 8" jointers for that matter.
I have a smaller "portable" planer - it's heavy, but it can be moved around (and stored on a shelf). You could mount a larger planer on a mobile base.
Larry Clinton At Frankfort (Central)., Indiana
>Although I have a fairly large shop (30' X 30'), all my major equipment is on mobile bases. My joiner is the Grizzly 8" with the 75" bed, I have a Rockler mobile base under it. I have a lunchbox planer on a steel table with the same base under it. I also have a 20" Yorkcraft planer (with the Byrd head). It came with a built in mobile base. Many of the current crop of joiners and planers are available with mobile bases. If you have or are going to purchase a "lunchbox" planer, you can either carry the unit to a storage area or build a table and install a mobile base.
Lee Gordon
>When I bought my jointer from (occasional forum participant) Barry Burke, he had already mounted it on the platform shown in this picture. Besides raising the machine five inches to what I find is a very comfortable working height, it also makes it easy to slip a hand-truck under the whole assembly and move it around with relative easy.
Like my Rojek *LINK*
JohnM in Mid Mich
>I came into one of the Euro conversion jointer/planers via a great eBay deal: the Rojek MSP-310. Didn't think I wanted that much machine, but man, is it great. Tremendous power (3.6 hp, electric brake), 12" wide, real quality unit. I use the jointer more than the planer function, but in a smaller shop the combo is great. Have all but put my Dewalt 12" "lunchbox" planer out to pasture. Lots of woodworkers will tell you that you should get the widest jointer you can afford, and I'll now agree. I've used the full 12" more than I ever imagined. Surely, an 8" would be pretty good too. Longer beds might be nice, but I have the table extensions that Rojek sells, and they work great. They come off and on in seconds, so that the main machine stays compact. As to mobility, this thing is a BEAST. I have it on a mobile base, but at about 550 lbs, it is a workout to move it anyway. If I had the money, I'd be getting the slot-mortising attachment that is available. Good luck in the search.
Rojek Jointer/Planer
Hal
>I have the Griz G0490. Am pleased with it after a year of service. It has a built-in mobile base which works well. I only have half of a standard double garage to put all my stuff in when the car comes in for the night, but have worked it out. Anything heavy is on mobile bases. Good luck. Hal
Re: Like my Rojek
Bill Earl
>I love my Rojek also. I bought an MSP-415 to replace a WoodMaster 718 and a 6" Delta jointer. The Rojek footprint is quite a bit smaller than the combined footprint of those two machines.
Having jointer capacity on-par with your planer makes a lot of sense. I get a lot of 12-14" stock, so the 16" capacity for both jointing and planing is great. The Tersa head makes blade-changing a snap.
As a jointer, the Rojek cuts clean and handles board up to 8' long with no problem. With longer stock, I use infeed rollers to augment the relatively short infeed table.
As a planer, it is much better machine than the WoodMaster: Better design, better materials, better construction and better precision. This all amounts to cleaner cuts with more repeatable thickness.
The power and electricals are first-rate. Even on full-width cuts, it barely slows down. There are interlocks to prevent unsafe operation. There are also emergency stop buttons at both the infeed and outfeed ends of the machine.
Dust collection is very good in jointer mode and OK in planer mode. (Comperable to the Delta jointer, but still head and shoulders above the WoodMaster planer.) A 16" cutter can generate a large volume of chips. A 6" hose connection would be better than the 4" as equipped.
At 800 pounds, it overwhelmed a ShopFox "Super Heavy Duty" mobile base. I ended up building a custom base for it. It is still alot of iron to push around, but I can make space when I need it.
I sold the Delta jointer and converted the WoodMaster to a full-time drum-sander.
