Like The Shop Fox Very Much
George@Colonel's Workshop
>Good Afternoon Pete,
I went thrugh the same quandry three years ago or more. I was able to test drive the PC, Jet, and Fisch. These all worked very well, although I definitely favored the Fisch's somewhat smoother operation. That could have been chisels. After more thought, I decidsed on the Shop Fox #W1671. I ordered it on line and had it delivered within 36 hours! It had greater capacity and capability than the others I had tested, and the motor was 3/4hp. It was supported on stout dual posts, could be rotated on its base to mortise off the table if needed, and the handle was adjustable. I came with a standard fence/hold down arrangement which I replaced with a cross slide vise from Harbor Freight. You need one of those critters for sure. If the mortiser you select has one, great! If not, buy an inexpensive one one ($50-$60)from HF or Grizzly. You can align the chisels with the lay out marks, crank and pull, and the mortise is done. I bought a set of Fox Shop chisels and they have satisfied my non-commercial needs. It was a very good decision, and I'd buy it again.
George
